88-91 oem spring rate?
Old Mar 3, 2005 | 05:03 PM
DpSyChO's Avatar
Default 88-91 oem spring rate?
Anyone know the spring rate for 88-91 hatch/crx? I've found on the web DA/DC/EG/EK but no listings for the hatch/crx.
Old Mar 3, 2005 | 07:02 PM
Superhatch's Avatar
Default Re: 88-91 oem spring rate? (DpSyChO)
I called up eibach once, and talked to a tech. He was more than willing to tell me spring rates for all of their products, and I'd be willing to bet they would have the stock rates.
Old Mar 3, 2005 | 08:49 PM
cursED's Avatar
There is also some mention in the RR/AC forum FAQ.
Old Mar 3, 2005 | 09:05 PM
crxgator's Avatar
250 and 150...
Old Mar 4, 2005 | 02:20 PM
DpSyChO's Avatar
Default Re: 88-91 oem spring rate? (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">250 and 150...</TD></TR></TABLE>
Damn,I figured the springs on my hatch would be a lower rate than an integra.Looking on the web,I found different listings for integras,here is the different numbers I found,dunno which ones are right as different forums listed different rates.
Front Rear
ITR. 247L 150-247P
GSR/DC. 263L 143L
GSR/DC. 212L 147L
GSR/DC. 242L 173L
DA 212L 117L
I dont know if any of these are correct.Now,I have laying around a set of 93 Integra LS,98 Integra GSR,98 Civic 4-door.
I know the spring diameter /Coil diameter/Number of coils determin the spring rate,the 98 civic is 1" longer than the 93 ls,and the 98 GSR is 1" longer than the 98 civic.All 3 are the same number of coils.I got a set of the struts with adj spring perches,,,not coilovers,but 3 positions for the spring perch,middle one is stock height,,so,I was gonna go ahead and use the set with the highest spring rate so I'll be set when the LS motor goes in.Is the 88-91 civic oem rate really that high?
Old Mar 4, 2005 | 03:47 PM
JohnnyB70's Avatar
Are they integra struts? Cause keep in mind that the integra struts/shocks are about 1.5 inches longer that stock civic shocks. I had a guy sell me some shocks and then found out they were integra shocks, when i put them side by side with the stock shocks they were much longer.
Old Mar 4, 2005 | 07:21 PM
DpSyChO's Avatar
Default Re: 88-91 oem spring rate? (JohnnyB70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyB70 &raquo;</TD></TR><TR><TD CLASS="quote">Are they integra struts? Cause keep in mind that the integra struts/shocks are about 1.5 inches longer that stock civic shocks. I had a guy sell me some shocks and then found out they were integra shocks, when i put them side by side with the stock shocks they were much longer. </TD></TR></TABLE>
They are 92-95,and I got a set of 98 civic 4 door struts from the junkyard for the "forks" to use for the front,thats why I have those springs.I dont really want to lower it,just run the highest spring rate of the springs I have and try to keep it stock height with a B18,thats why I got the struts with the different positions for the perch.Hopefully I'll have time and money to swap it in between spring/summer semester break.Just tryn to get suspension and what not ready now so it'll be less to do then.
effin
Suspension & Brakes
Mar 16, 2011 12:35 PM
dacrxguy
Oct 1, 2009 11:00 PM
drewbie*
Suspension & Brakes
Apr 27, 2007 10:06 AM
integraXTC
Suspension & Brakes
Jul 28, 2006 07:56 AM
kndaqikEG
14
Dec 31, 2004 08:54 AM
