Taking the original paint off is a B****... help !!!!
Old Mar 3, 2005 | 03:10 PM
G-bonic's Avatar
Hijacked
Default Taking the original paint off is a B****... help !!!!
I just bought this itr wing for $100 and im trying to take the paint off and its just so damn hard... i just wanna do it myself coz i dont have money to pay the shop to take it off and pay em an hour doin it and then paint like my color (frost white).. is there anyone here knows how to take the paint off easier than sanding it out manual, sanding it out is just so hard coz the paint is thick.. is there any liquid thing that u can just pour on em and it will take the paint off? if any of u here got any idea how to take the paint off easy let me know.. thanks in advance.. heres the pic of it tryin to peeling it off wit spatula..
Old Mar 3, 2005 | 03:13 PM
.water's Avatar
Default Re: Taking the original paint off is a B****... help !!!! (Stock_LS)
there is spary can that remove paint...air craft remove somthing...haha u were sanding that ??
Old Mar 3, 2005 | 03:15 PM
G-bonic's Avatar
Hijacked
Default Re: Taking the original paint off is a B****... help !!!! (Chris DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">there is spary can that remove paint...air craft remove somthing...haha u were sanding that ?? </TD></TR></TABLE>
hehe seriously i was sanding it down just for only like 2 mins., but im like fukk this shiet this will take me 1 yr. to finish its so thick.. by the way where can i get those spray can paint remover ???
Old Mar 3, 2005 | 03:22 PM
DC4KiD's Avatar
I don't think it's wise to use paint stripper on that wing... unless you want it desinigrated.
An orbital sander will get the job done
Old Mar 3, 2005 | 03:29 PM
gluxxxTEG306's Avatar
get an orbital sander and use a low grit sandpaper, seems like your using a flathead to scrape off the paint, dont do that! youll leave marks on the wing later, even after paint.
Old Mar 3, 2005 | 03:36 PM
G-bonic's Avatar
Hijacked
Default Re: (gluxxxTEG306)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gluxxxTEG306 &raquo;</TD></TR><TR><TD CLASS="quote">get an orbital sander and use a low grit sandpaper, seems like your using a flathead to scrape off the paint, dont do that! youll leave marks on the wing later, even after paint.</TD></TR></TABLE>
get orbital sander where ? how much they cost ?
Old Mar 3, 2005 | 03:42 PM
Haleiwa-Brando's Avatar
Default Re: (Stock_LS)
It is obvious you know little about body work but that's okay
All you need to do is get it ready for paint (your final color). This is as simple as sanding down the finish that is on the wing right now. You do NOT have to strip the color completely off, you just need a microscopicly rough and clean surface for the new primer to adhere to, followed by your color then your clear coat. It's pretty easy, but your making way too much work for yourself the way your going. Remember, since your going to be painting it Frost White, you want to go with a primer that is a light grey. If you go with a dark primer it could throw the hue off and then it wouldn't match properly.
Good luck.
Old Mar 3, 2005 | 03:56 PM
jdmjeff's Avatar
Default Re: (Haleiwa-Brando)
why dont you just primer it and then get it painted? why scrap it!!!
Old Mar 3, 2005 | 04:00 PM
2hatchs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">It is obvious you know little about body work but that's okay
Good luck.</TD></TR></TABLE>
all true
but now that you have f'ed up the finish you might as well go ahead and strip it. go to wal-mart or an auto parts store and get paint stripper for abs bumpers. its made for abs bumpers therefor it will not hurt the wing. although its not abs it will work. then prime it, paint it, and clear it. good luck
Old Mar 3, 2005 | 04:30 PM
GeorgeJetson's Avatar
You dont have to take the paint completely off to repaint it
Old Mar 3, 2005 | 04:40 PM
hondasport2000's Avatar
Words of wisdom
Old Mar 3, 2005 | 04:45 PM
fknslmd's Avatar
Default Re: Taking the original paint off is a B****... help !!!! (georgejetson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgejetson &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to take the paint completely off to repaint it</TD></TR></TABLE>
exactly, all you had to do was wetsand the clear with 400grit paper. you just turned a simple half hour job into a mess.
Old Mar 3, 2005 | 04:55 PM
XxSOHCDriVerxX's Avatar
yeah what he said
Old Mar 3, 2005 | 05:32 PM
shortSHIFT's Avatar
dang foo.....you scratched that thing like it was a lucky lottery ticket.....seems like you actually used ur keys for the job!
Old Mar 3, 2005 | 06:37 PM
elwood's Avatar
wow.....you really ruined that thing.
Old Mar 3, 2005 | 07:08 PM
Hawkze_2.3's Avatar
Jeez...soak it in a bathtub full of carb cleaner.
No, but seriously, just smooth out the part you fucked up until it feels smooth to your fingers and sand the entire wing just to rough up the surface, not strip the paint.
Old Mar 3, 2005 | 07:10 PM
migs's Avatar
Default Re: Taking the original paint off is a B****... help !!!! (Hawkze_2.3)
Buy something called BIX from Lowe's. Itll eat that **** alive.
Ri5e's Avatar
why would you put a type r wing on a stock ls?
Old Mar 3, 2005 | 07:20 PM
dxhatch92's Avatar
Default Re: Taking the original paint off is a B****... help !!!! (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">why would you put a type r wing on a stock ls?</TD></TR></TABLE>
maybe because its his car and he can do whatever he wants
Old Mar 3, 2005 | 07:21 PM
cyb3rjak's Avatar
because it looks cool!
reza
Default Re: Taking the original paint off is a B****... help !!!! (vitekboi)
how about some sanding and primer? why the **** would you want the paint off? its going to repainted right...
dayam you ruined that thing.
Old Mar 3, 2005 | 07:22 PM
reza
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gluxxxTEG306 &raquo;</TD></TR><TR><TD CLASS="quote">seems like your using a flathead to scrape off the paint.</TD></TR></TABLE>
ahahahahhaha!!!!!!!
Old Mar 3, 2005 | 08:13 PM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitekboi &raquo;</TD></TR><TR><TD CLASS="quote">
maybe because its his car and he can do whatever he wants </TD></TR></TABLE>
dont hate
Old Mar 12, 2005 | 11:50 PM
Dc2 Powered's Avatar
LMAO WTF.. you should of called me..
and how the hell are u standing the wing up like that? ud ont have the screws on there?
Old Mar 12, 2005 | 11:54 PM
RuthlessEF-9's Avatar
Default Re: Taking the original paint off is a B****... help !!!! (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it's wise to use paint stripper on that wing... unless you want it desinigrated.
An orbital sander will get the job done </TD></TR></TABLE>
heres your answer
DelSol12345
Paint and Body
Mar 30, 2009 06:00 AM
wdissident
Paint and Body
Jan 25, 2009 09:09 AM
Ekfor
Paint and Body
Apr 2, 2008 04:07 PM
Spry
Mar 21, 2004 04:13 PM
JDMITR22
Jan 5, 2004 06:41 PM
