Leaking coolant only when Defrost is on
Old Mar 3, 2005 | 12:58 PM
deechiguy's Avatar
Default Help!! Leaking coolant only when Defrost is on
Both of my Hondas (96 Accord 01 CR-V) leak coolant when only the defrost is running. My radiator is fiull and the overfill tank is between max and min. I noticed it a few days ago with all teh snow. But when the heater is on there is no coolant leak. No coolant leak with both defrost/heater on. I run the defrost on both Hondas without the A/C on. Any ideas?
Modified by deechiguy at 10:05 PM 3/3/2005
Old Mar 4, 2005 | 07:12 AM
deechiguy's Avatar
Default Re: Help!! Leaking coolant only when Defrost is on (deechiguy)
Any ideas? Anyone?
Old Mar 4, 2005 | 08:14 AM
Obsidian's Avatar
Probably have a leak in one of the lines that goes to your heater or a leak in your heater inside the car. If it smells like coolant inside your car then your leak is probably inside your car.
If not then check the outside. Try following the hoses and see if one of the connections has green crud around it. If so then there is your leak. If not then keep looking.
Old Mar 4, 2005 | 08:53 AM
deechiguy's Avatar
Default Re: Help!! Leaking coolant only when Defrost is on (Obsidian)
I checked around last night. I let the defrost run for like 10 minutes and it didnt leeak anywhere. I looked underneath and nothing. Maybe it was a one time thing.
SpazMan
Jun 12, 2008 10:22 AM
anduhy
Nov 19, 2007 11:44 PM
dunkd
Nov 13, 2003 07:28 AM
RAiMA
Jul 20, 2003 04:36 PM
Blue teg
Dec 17, 2001 07:21 PM
