Bushing Press?
Old Mar 3, 2005 | 11:08 AM
LawlessOne's Avatar
Default Bushing Press?
What kind and where to buy a press to use on suspension bushings?
I'm thinking it might be better to buy a press and do them myself.
I'm not sure of the size of die(s) needed, I have a 93 Accord, are all years/models using the same size bushings?
Also, I'm going to put some poly's in, I know replacing the rear trailing arms with poly is not recommended. Are there any on the front that should not be replaced with poly?
I would imagine that all/most of my bushings are shot, due to age, so I ordered a hyperflex kit from ES and the motor mount inserts as well.
I realize that everyone says that the poly's "ride way harsher", but I can't imagine anything riding harsher than a bunch of worn bushings/springs/blown struts, can you?
I have Tokico HP's on the way, H&R Sports 1.75 & 1.5, and the bushings. I would think that this set up would be way smoother than the old beat up crap that is on it now.
TY.
Old Mar 4, 2005 | 08:32 AM
ricepicker's Avatar
Default Re: Bushing Press? (LawlessOne)
You could probably take all the components to an alignment shop or a shop with a press and they would be able to press them out. It would be a lot cheaper than buying a press.
Old Mar 4, 2005 | 08:48 AM
RyanD03's Avatar
Default Re: Bushing Press? (ricepicker)
hell yes
Honda Type R
14
Jul 13, 2015 07:34 PM
Konigretracts
Nov 22, 2012 05:05 PM
siguy44
Suspension & Brakes
Aug 10, 2009 11:52 AM
The Internet Tough Guy
Oct 25, 2003 07:47 PM
dom93hatch
14
Aug 6, 2002 02:58 AM
