timing question
Old Mar 3, 2005 | 10:59 AM
gnar kill's Avatar
Default timing question
ok this may be stupid......I am getting ready to do my mini-me swap and when I set the crank and cam at TDC where to I position the rotor on the dizzy? I did a search and all I could find was "put the rotor for the dizzy in the correct location" also I know you need to do something to the ecu to get it to not correct the timing. Everyone says to jump the maintance connector or something like that and I don't really understand what they mean can someone explain this to me please....sorry this is probably a pretty noob question I just want to make sure I get everything right when I do my swap. Thanx
Old Mar 3, 2005 | 11:02 AM
sporkcrx's Avatar
Default Re: timing question (gnar kill)
You'll want to set the mechanical timing of the engine (block and head) at TDC, make sure the rotor is facing cyl 1 and not the opposing tower on the distributor. The service connector is in the engine bay, by the driverside fender. Usually has a yellow cap over it, that you pull off, and short the two connectors.
Old Mar 3, 2005 | 01:15 PM
gnar kill's Avatar
Default Re: timing question (sporkcrx)
I looked around for that service connector but couldn't find it....can anyone help me out jsut a little...sorry I am a noob.....thanx
Old Mar 3, 2005 | 01:24 PM
EP3_05's Avatar
88-89-The connector is in the engine bay as stated
90-91 The connector is underneath the dash near the ecu I believe
Old Mar 3, 2005 | 01:35 PM
gnar kill's Avatar
Default Re: timing question (91civic)
its a 91 and if it is that little blue clip I found it....so I just jump those two little parts of that clip together and then I am good to go right
Old Mar 3, 2005 | 01:38 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">its a 91 and if it is that little blue clip I found it....so I just jump those two little parts of that clip together and then I am good to go right </TD></TR></TABLE>
Yup jump the connector with a paperclip and time away.
Old Mar 3, 2005 | 01:43 PM
gnar kill's Avatar
good thanx....I am so excited to do my mine-me swap....I can't wait until my parts get here
Old Mar 3, 2005 | 01:55 PM
mellon's Avatar
You can only have the rotor facing one direction because the dizzy is keyed onto the cam and the rotor is keyed onto the dizzy.
Old Mar 3, 2005 | 01:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Jumping the service connector is for setting the ignition timing..
The cam timing/crank timing is something entirely different..
Before disassembling the engine,You want to set the crank
at "top dead center" with the #1 piston at the end of its compression stroke..
To Do This:
With the valve cover and spark plugs removed,rotate the crankshaft
counter-clockwise until you see the #1 cylinders intake valves open
and close..From there rotate the crank until the piston comes to the top..
That will be "#1 TDC" and the distributor rotor should point toward the #1 station in the distributor cap..
Integra4lyfe069
Apr 24, 2011 10:19 AM
31flavorscivic
Mar 22, 2009 10:58 PM
airikkCRX
Jul 9, 2005 09:59 AM
BABY NSX
Jun 15, 2001 07:47 AM
