EDM B18C6 header
hi,
anyone got a pic of the OEM B18C6 EDM header without the shield, as i am meant to have one on my B18C-R (the original 4-1 was damaged
) but it doesnt look right. Will try and get a pic of mine up, but want something to compare it too
the upper 1/2 is tubular steel vs. the cast iron unit that the US gets...
the lower 1/2 is still the same as far as I know.
sorry.. I don't have any pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">If you really have this EDM header on your JDM B18C, remove it quickly. It's useless. Primary tubes are 40 mm OD or something.</TD></TR></TABLE>
The collector is 42mm inner diameter:
Stock EDM b-pipe has 45mm ID, just FYI:
wow, awsome info guys, thats what i have
I do have a UK ITR mani on a B18C-R, as i spent all my cash on the swap, and got one real cheap
I also only have a 50mm ID exhaust system, again as it works and was already there.
I spent the money finishing off the chassis (Coilovers, ITR sways etc) and tracktime, as 180-90bhp is fine for now, just learning the car, as its a big change from 130bhp and no LSD. More power will come when i can afford the real thing
Out of interest, how exactly do you 'remove' the restriction, take its a dremel job
I also only have a 50mm ID exhaust system, again as it works and was already there.I spent the money finishing off the chassis (Coilovers, ITR sways etc) and tracktime, as 180-90bhp is fine for now, just learning the car, as its a big change from 130bhp and no LSD. More power will come when i can afford the real thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicESi »</TD></TR><TR><TD CLASS="quote">Out of interest, how exactly do you 'remove' the restriction, take its a dremel job
you have to cut the first ~9cm of the cat-back off and install a 'taper cone' of some sort.
</TD></TR></TABLE>you have to cut the first ~9cm of the cat-back off and install a 'taper cone' of some sort.
wilcoelskamp
Aug 7, 2007 11:03 PM
stuntinhb
Feb 20, 2007 12:02 AM
