DOHC VTEC - Oil Control Orifice - wtf does it do?
Old Mar 3, 2005 | 09:51 AM
dunkd's Avatar
Default DOHC VTEC - Oil Control Orifice - wtf does it do?
Number 9.
My block is missing it and I am going to Honda today to order one but I was just wondering what exactly it is there for? I am glad that I noticed I didn't have it because it looks like something anyone could easily oversee.
Also how does it go in? Just slips in there and then it is held in by the head?
Old Mar 3, 2005 | 10:23 AM
dunkd's Avatar
it is the silver thing on the top right of this pic
Old Mar 3, 2005 | 10:36 AM
Blue Hybrid's Avatar
Default Re: DOHC VTEC - Oil Control Orifice - wtf does it do? (dunkd)
that controlls your oil pressure, i dont think you can get an aftermarket one, you have to get a stock one from dealer, or doner, but yes you have to have it, and i hope that line isnt for lsvtec, cause its too skinny : P looks like a -4
Old Mar 3, 2005 | 01:03 PM
h22 civic's Avatar
Default Re: DOHC VTEC - Oil Control Orifice - wtf does it do? (gold EF)
i think only the h22s dont use that orrifice
Old Mar 3, 2005 | 02:56 PM
Default Re: DOHC VTEC - Oil Control Orifice - wtf does it do? (h22 civic)
really? i didnt know that, my b16 has one, my ls has one, and my gsr has one...
Old Mar 3, 2005 | 04:25 PM
drdisco69's Avatar
Default Re: (dunkd)
The oil control orifice controls the amount of oil reaching the head. Pretty straight forward.
If that is your block...
<rant>GET THAT BRASS TEE FITTING OUT OF YOUR BLOCK. IT _WILL_ BREAK OFF AND SPRAY OIL EVERYWHERE. You can ask anyone who has tried that, the weight of the oil pressure sensor and the vibration of the engine will cause the fitting to break off at the threads, leaving some in the block. The proper way to run the line is either directly out of the back of the block, or running a line from the block to a tee fitting that is secured somewhere else, and then attach the oil pressure sensor and the line to the head to that tee. Just making sure nothing happens to you </rant>
If that's not your block, forgive me for flipping out, I just see that stuff way too much.
Old Mar 3, 2005 | 06:23 PM
dunkd's Avatar
picture is not from my block... it is from the Endyn website.
however, my setup looks the same. The OEM sensor weighs close to nothing. The only times I have heard of people having problems is when they try to hang the Autometer Oil Pressure Sender off of a tee fitting, which is MUCH heavier.
But I am changing my setup to run to the firewall because I am going to be running the Oil Pressure Gauge.
I ordered the orifice and oring from Honda today for like $5.
Anyone have some info on installing it?
Old Mar 3, 2005 | 08:59 PM
drdisco69's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">it is from the Endyn website.</TD></TR></TABLE>
Well in that case, I hope they leave it there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">The OEM sensor weighs close to nothing. The only times I have heard of people having problems is when they try to hang the Autometer Oil Pressure Sender off of a tee fitting, which is MUCH heavier.</TD></TR></TABLE>
Well let me tell you about mine breaking off with the stock sensor. Just because it weighs very little doesn't mean it can't have enough force through the vibrations of the block to break the brittle threads cut into the grain of the brass. If you want, try it and see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have some info on installing it?</TD></TR></TABLE>
Slip the o-ring on and just pop it in to the block. May want to use a dab of oil to help it in.
Old Mar 4, 2005 | 09:37 AM
dunkd's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Well let me tell you about mine breaking off with the stock sensor. Just because it weighs very little doesn't mean it can't have enough force through the vibrations of the block to break the brittle threads cut into the grain of the brass. If you want, try it and see.</TD></TR></TABLE>
so yours broke off? what did u do to fix it?
A shop around me did this on a kids car (hung the big Autometer Sender Unit) off of a tee. It broke after about 100 miles I think. Then the shop JB welded it back together and put the same thing back in!! and ofcourse it broke again... not sure how the motor sits now.
Old Mar 4, 2005 | 03:40 PM
Default Re: (dunkd)
ghetto... hahaa jbweld...
just throw it in the trash
Old Jun 1, 2005 | 07:02 PM
nissanjon's Avatar
Default Re: (gold EF)
maybe i missed it, but how exactly do you remove the oil control orifice? thanks!
Old Jun 1, 2005 | 08:18 PM
Runnerdown's Avatar
Default Re: (nissanjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissanjon &raquo;</TD></TR><TR><TD CLASS="quote">maybe i missed it, but how exactly do you remove the oil control orifice? thanks!</TD></TR></TABLE>
Thread a bolt in and it just pulls out.
gtlaw
Mar 1, 2005 01:23 PM
SHhh__VTEC
Mar 1, 2004 09:20 PM
kerby116
Feb 28, 2004 04:55 AM
tgreaves
Nov 7, 2003 07:42 AM
KS-R
Jan 17, 2002 01:44 AM
