crx problem please help
Old Mar 3, 2005 | 09:43 AM
happy!'s Avatar
Default crx problem please help
when im driving my 88 si, the check engine light will come on and then die right after. I think its the main relay, cause sometimes it will not prime when i try to start it, but im not really sure. if it is main relay where exactly is it so i can replace it. any help would be greatly appreciated.
Old Mar 3, 2005 | 10:26 AM
superbeastcrx's Avatar
Default Re: crx problem please help (happy8301)
they are under the hood, and under the dash!
Old Mar 3, 2005 | 10:34 AM
EP3_05's Avatar
A CEL(check engine light) usually means the ecu is outputting an error code. Check your ecu led and count the blinks and that is the code. Look up the code in the manual or on here and find out what the problem is.
Old Mar 3, 2005 | 10:41 AM
happy!'s Avatar
Default Re: crx problem please help (91civic)
where can i find that on here
Old Mar 3, 2005 | 10:43 AM
go to the ef forum and click new topic, after doing this type what code it is and a question mark!
Old Mar 3, 2005 | 10:55 AM
crxtreme89h's Avatar
Default Re: crx problem please help (superbeastcrx)
Here is a few websites for the codes. Save them to your favorites.
https://honda-tech.com/zerothread?id=468260
http://tech.hybridgarage.com/tech/codes.html
http://www.geocities.com/chipman_13/ecu.html
Look here for replacing your Main Relay, which happens to be inside of the car and not in the engine compartment. That would be your main fuse.
http://www.markl.f9.co.uk/howt...y.htm
http://www.crxsi.com/resources/ <---here to but you will have to register
Also, it's under the drivers side kick panel. Should say Mitsuba if it's the original.
Old Mar 3, 2005 | 11:00 AM
happy!'s Avatar
Default Re: crx problem please help (crxtreme89h)
thanks guys
harker
Jun 23, 2009 03:22 PM
annab
Jul 28, 2008 04:01 PM
az90civic
Sep 7, 2007 08:05 AM
HSPxNick
Oct 16, 2006 11:27 PM
pez1
Jan 27, 2006 08:03 AM
