Si conversion.....
Old Mar 3, 2005 | 09:35 AM
MrPotatoeHead's Avatar
Default Si conversion.....
Ok ive searched and came up with nothing(mabe i just suck at it). I have everything to convert my car to Si except the injector wires, I cant find them anywhere. i was wondering if i can use injector wires from an obd1 honda? Because i have an extra harness laying around...Thanx for the imput.
Old Mar 3, 2005 | 09:55 AM
EP3_05's Avatar
Default Re: Si conversion..... (OnE sToCk CrX)
Do you mean the clips or just the actual wiring? You will need OBD0 clips but any "wiring" will work as long as it is the correct guage.
Old Mar 3, 2005 | 10:09 AM
Blue Hybrid's Avatar
Default Re: Si conversion..... (91civic)
what motor do you have? not a d15 right?
Old Mar 3, 2005 | 10:17 AM
Default Re: Si conversion..... (gold EF)
yea i have a d15
Old Mar 3, 2005 | 10:25 AM
d15 has only 2 injectors, thats why you cant find the other 2 : P haha
i assume you have the d16, or si
intake manifold, injectors (4)
distributor, ecu, and resister box?
Old Mar 3, 2005 | 11:07 AM
mrquimbie's Avatar
are you swapping an entire engine or just the MPFI stuff? Anyway, as said above you will need 4 obd-0 clips for the new injectors. You can also get them off an obd-0 integra engine harness. Thats where i got mine. If you need more instructions just do a search for dpfi to mpfi.
Old Mar 3, 2005 | 01:21 PM
520_Motorsports's Avatar
Default Re: Si conversion..... (mrquimbie)
i have a dpfi to mpfi subharness i will sell you. complete plug and play all you have to do is connect two wires to your dpfi harness and your good to go.
cgross
Dec 23, 2012 12:08 AM
sliiiiced
Jul 7, 2010 07:50 PM
motoguy126
Jun 26, 2010 04:24 PM
ivanson
Nov 5, 2005 06:00 PM
nucivowner
Mar 11, 2005 11:33 AM
