do i have to change my fuel pump? for a gsr swap in a crx???
Old Mar 3, 2005 | 09:09 AM
sleeper_crx88's Avatar
Default do i have to change my fuel pump? for a gsr swap in a crx???
well im trying to finish my gsr swap in my crx but it seems to lag when it gets to 4 grand and higher...my ecu is also throwing two codes: 7 and 41 could those codes be the reason why im not getting full power out of the motor??? it drives fine in the low rpm range. by the way the vtec is working. i converted my car to obd1...any help would be greatly appreciated thanks.
Old Mar 3, 2005 | 09:11 AM
EP3_05's Avatar
Default Re: do i have to change my fuel pump? for a gsr swap in a crx??? (sleeper_crx88)
Yes ecu error codes could cause the motor to run crappy. Fix the codes and the motor should run much better.
Old Mar 3, 2005 | 09:15 AM
Ef-er's Avatar
the fuel pump isnt the issue here,
its the codes your throwing
7 is throttle position sensor
41 is 0xygen sensor heater circuit
did u wire up the 02 properly?
and get a multimeter to check the tps
Old Mar 3, 2005 | 10:07 AM
AllMotoRex's Avatar
Default Re: do i have to change my fuel pump? for a gsr swap in a crx??? (ChineseGuy)
you dont need to change ur fuel pump. I have 91 dx and it has a gsr swap , i've been running the stock fuel pump for about a year now. Not one single problem or codes.
Old Mar 3, 2005 | 10:09 AM
AllMotoRex's Avatar
Default Re: do i have to change my fuel pump? for a gsr swap in a crx??? (AllMotoRex)
what point do you have your vtec set at? and are your secondaries working?
Old Mar 3, 2005 | 10:18 AM
Deetz's Avatar
Crazy Honda Guy
A fuel pump would only be needed if you were running boost or a NOS system.
speedjunkie_g35
Nov 22, 2012 01:18 PM
90AWDeclipse
May 29, 2011 11:07 AM
si90rex
May 24, 2006 06:31 PM
E-lude78
Jan 7, 2003 02:41 PM
metal-x
Jul 9, 2002 10:10 PM
