engine swap std. hatch
Old Mar 3, 2005 | 07:14 AM
nomotor's Avatar
Default engine swap std. hatch
do i need to anything besides mpfi conversion if i drop in a ZC 88-91 DOHC long block? is it just a drop in? i know with b-series i need mounts and obd conversion and swap axles
Old Mar 3, 2005 | 07:23 AM
EP3_05's Avatar
Default Re: engine swap std. hatch (nomotor)
ZC DOHC will drop in using your existing mounts. However, if you want to use a 5spd dx/si/zc transmission and axles you will need to change your hubs to either dx or si hubs.
Old Mar 3, 2005 | 11:09 AM
nomotor's Avatar
Default Re: engine swap std. hatch (91civic)
yeah im going to buy the swap from hmotorsonline with the ZC tranny too. so what axles do i need?
Old Mar 3, 2005 | 11:11 AM
aaronhume's Avatar
dx or si axles to go with the hubs and tranny
Old Mar 3, 2005 | 11:13 AM
nomotor's Avatar
Default Re: engine swap std. hatch (aaronhume)
so i need to get si axles, si hubs? would the same go if i was to get a D15B also??
Old Mar 3, 2005 | 11:17 AM
EP3_05's Avatar
the ZC trans uses an intermediate shaft which will require equal length axles. You will need 90-93 integra ls axles for the zc trans(i believe). For an Si/dx trans you will need si or dx axles. For whichever trans you get you will need si/dx hubs
Old Mar 3, 2005 | 11:18 AM
nomotor's Avatar
alrite thanks
Old Mar 3, 2005 | 11:19 AM
civicflow's Avatar
if you get the dohc trans you need to get a ZC intermediate shaft w/ 90-91 non abs integra axles. SI axles won't work, the SI hubs wil work with the integra axles though. one of the most common questions i see, if you search you will find all your answers.
Old Mar 3, 2005 | 11:20 AM
civicflow's Avatar
Default Re: engine swap std. hatch (civicflow)
damn, a little late in my post, hahahah
buckweeb101
Jul 3, 2013 12:52 PM
crxguy406
Jun 29, 2013 09:50 PM
JdM_RACeR07
Dec 4, 2006 01:37 PM
nasteboyii
Jul 26, 2004 02:00 AM
Phoenix1
Nov 18, 2003 08:05 PM
