Anybody ever try this? Hondata Airbox Modification
Old Mar 3, 2005 | 07:00 AM
Carlito Brigante's Avatar
Default Anybody ever try this? Hondata Airbox Modification
Yo crew,
I figured i would ask before i went ahead and started cutting up a brand new airbox. I know hondata always makes good stuff but will it really make a difference?
http://www.hondata.com/techkseriesairboxmod.html
Let me know what you think. I already have a intake on the way but i was planning on just using the tube to the stock airbox and then a k&n replacement filter.
Ricky
Old Mar 3, 2005 | 10:40 AM
jspec rsx's Avatar
yes it does make a little bit of a difference. In the stock airbox you can see especially on the filter that the air is only passing through one side of the filter. when you cut the stock air box it uses more of the air filter.. you cannot feel the difference but it should make a difference on the dyno
Old Mar 3, 2005 | 10:53 AM
t o m's Avatar
Default Re: Anybody ever try this? Hondata Airbox Modification (WIRED RICKY)
i started to cut it, but havent got to finish it. looks like it will make a difference.
Old Mar 3, 2005 | 10:54 AM
Default Re: (jspec rsx)
I kinda figured it wouldn't be a noticeable difference. The Plan is to keep it somewhat stock so i can at least juice 15G miles of the warranty or so.
Plus, i dont feel like paying for a V2 when it only makes about 6hp on this application. Just not worth it anymore.
Ricky
Old Mar 3, 2005 | 11:27 AM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WIRED RICKY &raquo;</TD></TR><TR><TD CLASS="quote">Yo crew,
Ricky</TD></TR></TABLE>
I've done this already and it doesn't make much of a difference. what you can do if hollow it out and then just take the suction tube out and that makes a big difference.
Old Mar 3, 2005 | 12:40 PM
Default Re: Anybody ever try this? Hondata Airbox Modification (aznbo1626)
Thanks for the input.
Ricky
Old Mar 3, 2005 | 02:32 PM
CBRF4i's Avatar
Its ok nothin special. i didnt notice anything.
Old Mar 3, 2005 | 04:55 PM
aspec04t's Avatar
Seems like an easy solution to make some cost effective HP. CAI will give a lot more gains
Old Mar 3, 2005 | 06:10 PM
mister x's Avatar
Be sure to do a clean job, the smoother the inside of the box, the better. It should inprove throttle response due to the larger air volume around the filter but yes the HP gains will be modest.
no show no go
Oct 3, 2011 10:41 PM
hondasaurusrex
Sep 30, 2006 09:32 PM
RsxType-Stitch
Dec 8, 2005 06:58 AM
RsxType-Stitch
13
Aug 31, 2005 07:00 AM
RsxType-Stitch
Aug 15, 2005 12:22 AM
