tokicos from a 91 integra work on a 97 civic?
Old Mar 3, 2005 | 06:55 AM
hybridej7's Avatar
Default tokicos from a 91 integra work on a 97 civic?
will tokicos from a 91 2dr integra ls work on a 97 civic? i searched, came up with a couple things but didnt answer my question.....thanks
Old Mar 3, 2005 | 07:25 AM
s2kc's's Avatar
Default Re: tokicos from a 91 integra work on a 97 civic? (hybridej7)
i dont think so, not from a 91, 94 up yes.
Old Mar 3, 2005 | 07:32 AM
purplegsr's Avatar
Default Re: tokicos from a 91 integra work on a 97 civic? (redb20teg)
I already posted this in the other thread:
You would need to use front drop forks from a 90-93 Integra or 88-91 Civic to make the fronts work (they are slightly smaller in diameter than the 92-00 Civic front shocks). The rear forks that are attached to the shock are going to be a little bit wider than the 97 shock forks - so you would want to take precautions to make sure the rear LCA, LCA bushing, and shock fork are firmly mounted - maybe put a new thicker bushing, or some sort of shim to anchor it better (or even swap in DA/EG/DC LCAs).
The most important difference is that the DA shocks are taller than the EK shocks, so you might have unpredictable ride height. If you have coilovers it shouldn't be a problem. Also, use the tophats from your Civic, not the Integra since the rubber inserts are shaped differently - if you don't have Civic tophats, you can use the Integra ones. I don't think there is anything a dremel or some creativity won't fix if you can't get the springs to sit perfectly.
I would also advise getting some brakeline brackets to go around the smaller front shocks, so you don't have to resort to zipties to hold your brake lines out of harms way.
Old Mar 3, 2005 | 07:47 AM
hybridej7's Avatar
Default Re: tokicos from a 91 integra work on a 97 civic? (purplegsr (Exospeed))
cool, thanks for the info. i didnt think they would, just wanted to make sure. i found a deal on a set of tokico 5-ways for a 91 integra but i wanted them for my 97 civic, so i was just going to swap them over but owell.....ill just get them for the teg.......
thanks for the help
Msnier85
Sep 16, 2007 07:51 PM
hybrid1990crx
Jan 7, 2006 11:16 PM
thelucysong
May 28, 2003 04:13 PM
wessieball
Mar 19, 2002 09:33 PM
Isaac
Mar 9, 2002 11:30 AM
