EF B16A power steering in a SEDAN...Is it possible? What's needed?
Old Mar 3, 2005 | 06:52 AM
jdmEFsedan's Avatar
Default EF B16A power steering in a SEDAN...Is it possible? What's needed?
Sup H-T members
I'm droppin in a B16A in my sedan and I'm planning to go for that "factory look". (as the topic states) Is it possible to keep my power steering?
What do I use? I figured B series power steering pump. What power steering lines? EF, DA, DC......? Will this work?
Thanks in advance for all your help.
Old Mar 3, 2005 | 08:44 AM
jdmEFsedan's Avatar
Default Re: EF B16A power steering in a SEDAN...Is it possible? What's needed? (EF_VTEC)
bump for some info!!
Old Mar 3, 2005 | 09:18 AM
EP3_05's Avatar
Hmmm...my xsi swap came with a power steering pump. I would assume you need the pump from the b series because I don't think a d series pump will mount to a b series block. It should work but I have a feeling you may need to piecemeal a system together like a b series pump and maybe d series lines but I am not too sure since I just packed the power steering system away in my basement.
Old Mar 3, 2005 | 09:26 AM
xci_ed6's Avatar
probably will need custom lines. it's cheap though. A local guy did a H22 into his accord and kept P/S. I think it was ~$15 for the custom line he needed from a local hydraulic shop.
jessedm
Dec 14, 2010 09:23 AM
_Keith_
Apr 5, 2009 09:53 AM
roger93si
Nov 16, 2007 04:58 PM
