Suspension & Brakes Theory, alignment, spring rates....
camber specs
Old Mar 2, 2005 | 10:50 PM
strsi's Avatar
Default camber specs
On a stock ek what is the camber generally at front & back?
Also, putting neuspeed sports on (1.75F/1.5R drop), how much do u think these will cause the negative camber to increase front & back?
I'm trying to figure out how much the rear will increase so that I know how many washers to use in the rear to get it back to factory camber.
Also trying to see what the front camber will be like so I can decide if i should get a camber kit for the front.
-Thanks
Old Mar 3, 2005 | 12:03 AM
bad-monkey's Avatar
Default Re: camber specs (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">On a stock ek what is the camber generally at front & back?
-Thanks</TD></TR></TABLE>
honda's factory camber specs are usually a range of -1.0 to 0.5 degrees or so. the new springs will increase negative camber, by anywhere from .5 a degree to a full degree or so. you won't need a camber kit unless you want to even out the camber F-R, L-R, or INCREASE negative camber for performance purposes. tire wear due to camber is a big bad overhyped boogie man, when in actuality it's more like a menacing picture of a boogie man. lower the car, get it aligned to zero out the toe and your tires should last a long time. as far as the washers go, trial and error is probably the easiest way to get the camber spec you want in the rear. i suggest a lifetime warranty at firestone or goodyear (~150 bucks, lifetime alignments for the life of the car) which will let you do the guesswork without paying through the nose for it.
Old Mar 4, 2005 | 08:28 AM
strsi's Avatar
Default Re: camber specs (bad-monkey)
So on a street car would u consider -1 degree in the front & -.5 degree in the rear optimal? Or should a keep it even like -1 all around?
Old Mar 4, 2005 | 09:17 AM
carl_aka_carlos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">So on a street car would u consider -1 degree in the front & -.5 degree in the rear optimal? </TD></TR></TABLE>
sounds good!
ek guy
Suspension & Brakes
Nov 5, 2008 07:11 PM
TailZ
Honda Civic (2001 - 2005)
Apr 29, 2008 08:13 PM
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
Wazup
19
Mar 11, 2004 06:18 AM
austrian type-R
Jul 23, 2003 07:42 AM
