b16 All motor
Old Mar 2, 2005 | 07:11 PM
KeithGSR's Avatar
Default b16 All motor
Hello my friend has a ef hatch with a b16 all motor setup with many crower internals. The car runs, but it sounds bad around the time vtec should kick in. supposedly he has work on the car many times and can not figure it out. He is running real high compression like 12 to 1 or 11.5 to 1...not sure. I thin he had it dyno tuned, anyways he is trying to sale me the car for 2k. Do you think its worth it? Whats the most do you think I'll have to put into a car like this to get it up and running? Any suggestions as to what the problem might be? I hope its something simple...
Old Mar 2, 2005 | 09:20 PM
98lsskunk's Avatar
Default Re: b16 All motor (KeithGSR)
so... vtec dosent kick in???
Old Mar 2, 2005 | 10:00 PM
KeithGSR's Avatar
Default Re: b16 All motor (98lsskunk)
Im guessing thats what happens...around that rpm it gets a powerloss and it bogs heavy...Someone suggested the dizzy, I thought that was replaced and is brand new. I'll try again...anymore thoughts?
Old Mar 2, 2005 | 11:34 PM
gvc3k's Avatar
first off who wold go allmotor in a b16? second buy the car and tell us how much maony u put into in 6 months
Old Mar 2, 2005 | 11:35 PM
gvc3k's Avatar
Default Re: b16 All motor (gvc3k)
oh yeah
check all the vtec parts. try chiping the ecu
Old Mar 3, 2005 | 09:10 AM
KeithGSR's Avatar
So whats bad about a all motor b16....I think I eventually want to sell the high compression parts and make it a b16 turbo???? but if I buy it now. do you think its going to be that difficult to maintain if its not a daily driver? Yeah there is some error code, supposedly he looked it up and it had something to do with the vtec?
Maybe the vtec was rewired and got hooked up wrong?
Old Mar 3, 2005 | 10:16 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gvc3k &raquo;</TD></TR><TR><TD CLASS="quote">first off who wold go allmotor in a b16?</TD></TR></TABLE>
Me and plenty others out there........
Old Mar 3, 2005 | 10:47 AM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gvc3k &raquo;</TD></TR><TR><TD CLASS="quote">first off who wold go allmotor in a b16? </TD></TR></TABLE>
I am b16 all motor, there somethin wrong with that?
Old Mar 3, 2005 | 10:57 AM
KeithGSR's Avatar
Default Re: b16 All motor (sheepeg3)
hey...update on exactly whats crackin. the b16 all motor is misfiring at 2500-3000 rpm....it bogs heavy after that... and also the vtec is not popping on. There is a error code.... does this sound like two different problems? the dizzy ?
Old Mar 3, 2005 | 11:24 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">There is a error code</TD></TR></TABLE>
what code is it?
Old Mar 3, 2005 | 11:58 AM
hatchinprogress's Avatar
Default Re: b16 All motor (EG6 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR &raquo;</TD></TR><TR><TD CLASS="quote">
what code is it?</TD></TR></TABLE>
Old Mar 3, 2005 | 12:54 PM
KeithGSR's Avatar
Default Re: b16 All motor (hatchinprogress)
Hatch, Im bout to find out...I keep missing his phone call..
Old Mar 3, 2005 | 01:09 PM
98lsskunk's Avatar
check the plugs wires and distributor thats probably whats causing the missing after 2500 because my ls did that before and it was a bad wire. as for the vtec problem check the oil line that pressurizes the selinoid, low oil can also prevent vtec from engaging. it could also be a problem with the rocker assembly or the selinoid itself
Old Mar 3, 2005 | 02:46 PM
KeithGSR's Avatar
its the code #22 the vtec selenoid oil pressure switch? He told me he as put a sensor from a 99 civic si with vtec, It should be working and brand new. I will test out these ideas over the weekend. Let me know if you got more
Old Mar 3, 2005 | 03:15 PM
greenbee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">its the code #22 the vtec selenoid oil pressure switch? He told me he as put a sensor from a 99 civic si with vtec, It should be working and brand new. I will test out these ideas over the weekend. Let me know if you got more</TD></TR></TABLE>
you could swap the old switch if it worked.
okay, first- take apart the switch and check the screens for blockage. then
disconnect battery, disconnect ecu and measure resistance from the connector at
the switch to the ecu connector, should be less than an ohm.
make sure your ecu is either chipped or the correct ecu for the engine do
this and get back.
Old Mar 3, 2005 | 05:17 PM
KeithGSR's Avatar
Default Re: b16 All motor (wesisrael)
no supposedly it went bad...I need to find a new one maybe for this model engine?
Old Mar 3, 2005 | 05:18 PM
milton's Avatar
wat ecu u running?
Old Mar 3, 2005 | 05:23 PM
KeithGSR's Avatar
Default Re: b16 All motor (milton)
I'm pretty sure its a stock b16 ecu...I'll post up info tomorrow.
Old Mar 3, 2005 | 07:08 PM
Kendall's Avatar
Realistically, your best bet is to bite the bullet and take it to a reputable shop and have them give you an opinion as to what exactly is going on. It may be component related and an easy fix, or it may be internal and require either a rebuild or a different motor. Fortunately B16 longblocks are cheap, and most component failures are easy to discover. Good luck.
Ummmm......ME!!!
Old Mar 5, 2005 | 03:43 PM
KeithGSR's Avatar
Default Re: b16 All motor (Kendall)
I just got back from towing the car to my place. Some ****...took me all day to get it sold. Well plans happened like they were suppose to. I'm going to start my mission with working on this car. I have a update for you guys to know about the dizzy... Its a weird ignition setup...so its a MSD 6A that routes to a ignition coil box...???? I guess...and that send like a normal 8.5 mm msd wire to the dizzy. the dizzy is a msd pro charger or something....and then the dizzy has four normal wires under the hood. I personally think MSD aint that good, I should go with NGK....? and maybe that might HELP? I think that will be step number... I still need to figure out if code 22 is related to my overall problem... Maybe I should start with that? how can I fix that????
Old Mar 5, 2005 | 09:15 PM
KeithGSR's Avatar
Crazy **** Yo, it has crazy stuff all over the place right now its running stock injectors but I can put on brand new 320 rc's, What fuel pressure is good. For a full compression 12.1 b16 do you have to run high octane fuel? First Im going to change the fluids, then Im going to check the wiring on the ecu...it has a spoon chip! thats crazy cool. vtec..is 5200 and rev is 9500? this car has tons of good stuff it just need a lil extra helping hand and its going to chirp bizzards....but yeah so this...so he says it has a loud pinging metal sound when it gets going....Let me know if you have anything to say...peace
Old Mar 5, 2005 | 10:31 PM
Terrible One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">so he says it has a loud pinging metal sound when it gets going</TD></TR></TABLE>
say what?
Old Mar 6, 2005 | 04:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithGSR &raquo;</TD></TR><TR><TD CLASS="quote">Crazy **** Yo, it has crazy stuff all over the place right now its running stock injectors but I can put on brand new 320 rc's, What fuel pressure is good. For a full compression 12.1 b16 do you have to run high octane fuel? First Im going to change the fluids, then Im going to check the wiring on the ecu...it has a spoon chip! thats crazy cool. vtec..is 5200 and rev is 9500? this car has tons of good stuff it just need a lil extra helping hand and its going to chirp bizzards....but yeah so this...so he says it has a loud pinging metal sound when it gets going....Let me know if you have anything to say...peace</TD></TR></TABLE> cool im glad you ot started
Old Mar 6, 2005 | 10:42 AM
KeithGSR's Avatar
hey hatch do you got some parts...like a dizzy?
can you use gsr cams on a b16
Old Mar 6, 2005 | 11:51 AM
UncleD's Avatar
FIRST OFF, who would make such an ignorant comment like this? Must be some **** tard like yourself who knows nothing about motors
