OBD1 GSR swap sputters from 1500-2000
Old Mar 2, 2005 | 06:39 PM
JohnnieChimpo's Avatar
Default OBD1 GSR swap sputters from 1500-2000
89 CRX HF
95 GSR
OBD1
seems to run rich,
sputters pretty bad under any kind of load 1500-2000RPM sounds like WRX or old VW.
other than that runs pretty much ok
Ideas?
Old Mar 2, 2005 | 06:41 PM
crxnj's Avatar
Default Re: OBD1 GSR swap sputters from 1500-2000 (JohnnieChimpo)
You have the butterflys(iab's) hooked up??
Old Mar 2, 2005 | 06:54 PM
Default Re: OBD1 GSR swap sputters from 1500-2000 (Mr.speaker)
yes but I don't know if they are working because Vtec isn't running because the speed sensor isn't hooked up.
Old Mar 2, 2005 | 06:55 PM
Rywire's Avatar
speed sensor? are you running a electronic one for a jdm cluster?
Old Mar 2, 2005 | 07:14 PM
Default Re: OBD1 GSR swap sputters from 1500-2000 (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">speed sensor? are you running a electronic one for a jdm cluster?</TD></TR></TABLE>
eventually a JDM cluster
I also need the signal to trigger the vtec
Old Mar 2, 2005 | 08:21 PM
efcivic757's Avatar
check timing, that will make your car run rich and sputter under load. Also Honda motors run a little rich normally.
Old Mar 3, 2005 | 04:52 AM
StorminMatt's Avatar
Default Re: (efcivic757)
Also, my USDM P30 tended to make my B16A do this if the VSS is not wired up (and you run a code 17). Hook up that VSS!. The one in the dash works fine. No need to use the electronic style VSS and a different gauge cluster.
Old Mar 3, 2005 | 05:31 AM
deftones0817's Avatar
Default Re: (StorminMatt)
sotrmin matt is correct you come here sayign you have a problem but your vss isnt hooked up of course you are having issues. Use a cable vss and get that stuff hookedup to your hf gauge cluster.
Josh
Old Mar 3, 2005 | 06:52 AM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">sotrmin matt is correct you come here sayign you have a problem but your vss isnt hooked up of course you are having issues. Use a cable vss and get that stuff hookedup to your hf gauge cluster.
Josh</TD></TR></TABLE>
yeah dito!!
get your VSS hooked up ASAP! your car will think your going 0 MPH all the time
Old Mar 3, 2005 | 01:11 PM
Default Re: (julio_bOostamante)
So my studder from 1500-2000rpm is from the VSS not being hooked up?
That doesn't seem correct since the car ran fine for the last 300 miles. This studder is new in the last week.
Old Mar 3, 2005 | 01:17 PM
EP3_05's Avatar
Default Re: (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">So my studder from 1500-2000rpm is from the VSS not being hooked up?
That doesn't seem correct since the car ran fine for the last 300 miles. This studder is new in the last week.</TD></TR></TABLE>
You failed to mention this in the original post. Check your timing both cam and ignition. Also what ecu are you running? Did you convert to OBD1?
Old Mar 3, 2005 | 06:00 PM
Default Re: (91civic)
The title of this thread is OBD1 GSR swap sputters from 1500-2000
YES, it is OBD1
Yes I checked my timing
No I did not check my belt, it is the original one from the factory, the engine is 45k miles.
Give me ideas that are not simple, I've checked the dumb stuff, new dizzy, timing on,wiring correct, correct computer
The car ran fine for the last 300 miles since the swap
This is a new problem.
Old Mar 3, 2005 | 07:30 PM
EP3_05's Avatar
YES, it is OBD1
Don't give me the hammer(j/k)...You failed to mention that it was a new problem in the original post. That makes a difference because it can narrow down the problem. Alot of times it is simple stuff with swaps. I've done 5 swaps and if they don't run or run poorly it is more often than not something stupid. Vacuum connections correct? Spark plugs gapped properly? Are they new plugs? Have you noticed how the gas mileage is? Is the sputter under full throttle or part throttle? Any ecu error codes?
94ej1civic
Jan 18, 2011 04:49 PM
boyee1
10
Dec 15, 2007 10:07 AM
HondaRexBoi
Mar 29, 2007 10:30 PM
hndakd
Nov 16, 2004 03:57 PM
dwchkypmp20
Mar 13, 2004 05:20 AM
