91 hf to 91 dx redline?
I have a 91 crx hf with 16valve head, dx trans,act stage 2 clutch, dc sports 4-2-1 header, aem adustable cam gear i want my rev limiter changed 2 dx becase hf is 6,000 and dx is 6,500 the only thing hf is my intake and computer **** i dont want the ugly *** dx intake what can i do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_QWIK_HF_CRX »</TD></TR><TR><TD CLASS="quote">I have a 91 crx hf with 16valve head, dx trans,act stage 2 clutch, dc sports 4-2-1 header, aem adustable cam gear i want my rev limiter changed 2 dx becase hf is 6,000 and dx is 6,500 the only thing hf is my intake and computer **** i dont want the ugly *** dx intake what can i do.</TD></TR></TABLE>
Im curious..What kind of pistons do you have..??
Yeah get the si intake manifold and ecu..That dx intake manifold and hf ecu is killing your car..
how are you running a 16v head with the hf block? or have you swapped the whole dx motor in? the hf pistons are set up for 8 valves not 16, so yea like the liketheemaddhatterr said. it's not gonna last long at all. i dont even see how you made it through start-up (if you are using the stock hf block)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_QWIK_HF_CRX »</TD></TR><TR><TD CLASS="quote">b15d hf block same as dx block
They have different pistons..You cant put a 16valve head onto the hf block without switching to 16 valve pistons..The hf pistons are setup for 8 valves.//
freezerburnv2
May 30, 2006 01:09 PM
SHG_Beans
Nov 27, 2003 07:53 AM
