90 Civic LS SWAP
Old Mar 2, 2005 | 04:42 PM
92CivicLS's Avatar
Default 90 Civic LS SWAP
im trying to swap the LS motor complete with ls motor mounts will it work, i already converted the car to fuel injection so no big deal there, im trying to just slap it on, so will the stock mounts with bracket work in the 90 civic with shiftlinkage????
some please help me out here im really trying to save $$$ on a mount kit because it has a blown headgasket.
Thank you !!!
Old Mar 2, 2005 | 04:59 PM
Ronin150's Avatar
Default Re: 90 Civic LS SWAP (92CivicLS)
Your gonna need a new shift linkage either made by hasport or another company, or you can modify an integra shift linkage. I'm not sure if you can use any year, but you have to cut it by 2/3 an inch (don't quote me on the length)
Old Mar 2, 2005 | 06:19 PM
Magick211's Avatar
Default Re: 90 Civic LS SWAP (Ronin150)
Im not sure what year car you have but i can tell you right now that you will need a mount kit?
Since you said you converted to fuel injection im guessing you have a honda older than 88. give more details.
Old Mar 2, 2005 | 06:40 PM
crxnj's Avatar
If you have a older car(84-87)..Then you should get the 88-89 integra motor/tranny/ecu..Everything bolts in perfect..
You can use the stock 90 civic linkage but its obviously going to have to be cut a little bit
Old Mar 6, 2005 | 07:19 AM
92CivicLS's Avatar
Default Re: 90 Civic LS SWAP (Mr.speaker)
1990 Honda Civic hatch Dual point fuel injection, now its a 1990 honda Civic hatch multi point fuel injection with SOHC VTEC # 3 Cylinder rod flew out the front.
now im getting a b18a with mounts shift linkage, harness everything but i wanna know if its gonna fit just like that.
i really dont have $$$$ to put on motormounts or linkage well my friend doesnt because the motor needs headgasket and water pump and timing belt. soooooo i need money there not on a kit im trying to save for HIM.
just let me know if im stuck or if i have hope with what i have.
Old Mar 6, 2005 | 07:23 AM
EP3_05's Avatar
Nope you are going to need a mount kit and linkage unless you are good at welding or know someone. You will need to relocate some of the brackets on the chassis in order to drop a b18a1 into a 90 civic with the stock b series mounts.
Old Mar 6, 2005 | 07:52 AM
PURPLETERROR aka BIGMATT's Avatar
You are going to need a b series mount kit, Hasport, hcp, enjo, ect, and also have to modify the shift linkage, cut and shorten it. You can use your modified harnes, that will work fine. Make sure you get the pr4 integra ecu also. Good luck with the swap, you should be able to get a new water pump, timing belt and headgasket for $130 from advance auto/discount auto. If i still lived in florida i'd give you a hand. Good luck
Old Mar 7, 2005 | 07:27 PM
92CivicLS's Avatar
Default Re: 90 Civic LS SWAP (PURPLETERROR)
Thankyou guys for everything i was talking to the owner of the car bestfrriend os mines, and he will be getting thses stuff thanx!
Thanx again!!!
Old Mar 7, 2005 | 07:30 PM
dr_latino999's Avatar
Where in Miami are you located, I may be able to give you a hand.
Old Mar 11, 2005 | 11:26 AM
92CivicLS's Avatar
Default Re: 90 Civic LS SWAP (dr_latino999)
i stay in miami (kendall) but im not doing this car yet im trying to get all the parts i need sooo. i'll write back as soon as im ready ok
Thanx!
pappaj
May 5, 2006 06:13 PM
asocallocal
Apr 22, 2005 06:40 PM
B20NonVTECTURBO
Feb 27, 2005 02:09 PM
The Rick 23
10
Jun 9, 2003 08:37 AM
89hondarex
26
Mar 20, 2002 06:38 PM
