Need help finding a 12v Power Source In EK
Old Mar 2, 2005 | 04:27 PM
Myh4tch's Avatar
Default Need help finding a 12v Power Source In EK
I'm wiring up my s2k engine start button and I need someone's help finding a good 12V power source that activates when I turn the key to the start position.
My mind is running a blank right now so any help would be appreciated... TIA!
Old Mar 2, 2005 | 04:32 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Need help finding a 12v Power Source In EK (Dawn Dreaming)
catch it off of the main relay. or look in the fuse box for an ign 12v. there should be 2 pins there hot with the ign on.
Old Mar 2, 2005 | 04:35 PM
saxqtzk's Avatar
the radio has a switched source
(Yellow/Red)
Old Mar 2, 2005 | 04:53 PM
Myh4tch's Avatar
Default Re: Need help finding a 12v Power Source In EK (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">catch it off of the main relay. or look in the fuse box for an ign 12v. there should be 2 pins there hot with the ign on.</TD></TR></TABLE>
can you explain more, i just looked under my fuse box and nothing really cought my eye, what exactly and i looking for?
Old Mar 2, 2005 | 04:57 PM
G3NR8's Avatar
Default Re: Need help finding a 12v Power Source In EK (saxqtzk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk &raquo;</TD></TR><TR><TD CLASS="quote">the radio has a switched source
(Yellow/Red)</TD></TR></TABLE>
DON'T use the radio power. Every time you push the button, your going to draw more current than the radio is fused for, thus blowing the fuse and you car won't start at all. Take off the drivers side under dash. If you follow the wires to the ignition column, find the thick black wire with a yellow trace. Thats your switched 12v wire. All your ignition wires are covered in plastic, just use something to cut the plastic away. You'll know its the switched power wire because it will be mixed in with the other ignition wires (yellow, white, black/white). Make sure you use a fuse on it just to be safe. I wouldn't use any other power source for an ignition related item....
Old Mar 2, 2005 | 04:59 PM
G3NR8's Avatar
Default Re: Need help finding a 12v Power Source In EK (G3NR8)
to give a bit more info in case you need it...
White is constant 12v
black/white is your starter wire
black/yellow is ignition
yellow is accessory (drops during crank)
white/black is 2nd accessory
Old Mar 2, 2005 | 05:03 PM
Myh4tch's Avatar
alright awesome help, so I should tap into the black/yellow wire comming from my ignition correct?
Old Mar 2, 2005 | 05:16 PM
Myh4tch's Avatar
back up for my question
Old Mar 2, 2005 | 05:25 PM
Myh4tch's Avatar
come back
Old Mar 2, 2005 | 07:29 PM
saxqtzk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 &raquo;</TD></TR><TR><TD CLASS="quote">
DON'T use the radio power. Every time you push the button, your going to draw more current than the radio is fused for, thus blowing the fuse and you car won't start at all. Take off the drivers side under dash. If you follow the wires to the ignition column, find the thick black wire with a yellow trace. Thats your switched 12v wire. All your ignition wires are covered in plastic, just use something to cut the plastic away. You'll know its the switched power wire because it will be mixed in with the other ignition wires (yellow, white, black/white). Make sure you use a fuse on it just to be safe. I wouldn't use any other power source for an ignition related item....</TD></TR></TABLE>
if you splice into it directly than yes you'll suck a good amount of power and blow the fuse.
When you're doing the s2000 button conversion you should have a relay and a seperate fuse line.
Old Mar 2, 2005 | 07:35 PM
saxqtzk's Avatar
Are you installing a aftermarket start button or an OEM S2000 Button?
Here's a how-to on a miata:
http://www.miata.net/garage/pushstart/
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory White/Black Ignition Switch Harness
STATek9
Feb 10, 2010 03:14 PM
O2DAB05
Jul 10, 2009 06:11 AM
dwuknoit
Nov 29, 2008 06:46 AM
crazyemokid
35
Jun 8, 2006 12:08 PM
Mugen Dom
Nov 13, 2001 08:32 AM
