Help me build my motor.
Ok here goes. I recently aquired a 94 gsr. Basically, i got the motor for free and got paid 600 dollars to pull the engine out of the car. Engine will be going into my 2000 civic si. Anyway, im ready to build it. Ive got the block torn down and ready to be built. My goals are this:
1. As much over 200 whp as possible.
2. Daily driven reliability. (i will put my b16 back in if something bad happens)
3. RLZ headword, Rocket cams
I need input on everything else. I will be assembling the motor myself. I have the money to spend on parts, now its just a matter of decided what parts to buy and why? I want to stay under 12.1 compression wise, as this car will be driven daily. Probably gonna go with hondata for tuning, but ill worry about that when the motor is built. Machine work is scheduled for next week, but i need to get my pistons before then, so help me out here. Thinking about an 81.5mm bore...
stageII skunk2 cams, skunk2 retainers and springs, p&p the head, ITR throttle body, skunk2 intake manifold, h22 injectors, ajustable cam gears, higher compression pistons "cast" like ITRs, shotpeen the rods, ARP rod/main/head bolts, ACL silicone injected bearings, have the head milled, bore the block, lightened flywheel, intake header exhaust, stageII clutch, hondata/skunk2 ecu, ajustable fuel press. reg., and have it tuned by the right person.
b18crxkid
May 19, 2011 10:53 AM
EtchaSketch
Aug 15, 2005 02:31 PM
