question......
Old Mar 2, 2005 | 01:57 PM
1988c-rex's Avatar
Default question......
My 88 crx si is having a problem starting up. It just started up two days ago. Now when i turn the key it cranks but won't start. The first time i tried and it putted for a minute so i figured it was low on gas. I put more gas in and it did the same thing so i turned it off and tried again. Now all it does is turns over but won't start at all...
Old Mar 2, 2005 | 02:03 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: question...... (1988c-rex)
Might be the main relay..
A good article on trouble-shooting a "No-start" situation:
http://autorepair.about.com/cs...a.htm
Old Mar 2, 2005 | 02:06 PM
doublethink's Avatar
how much gas did you add?
it could be a great many things, all of which are covered in the helms manual, which you can find here:
http://tech.hybridgarage.com/t...l.pdf
theres all kinds of troubleshooting, and how to fix anything on your car.
i dont mean to be all general, but theres no way to troubleshoot a car your not in front of really.
the basics of starting are fuel and spark. you need both. check to see if the fuel pump primes when you turn the key to the on position.
pull a spark plug wire and make sure you have spark against the valve cover.
much deeper then the very basics really should go to a professional mechanic.
good luck anyways.
Old Mar 2, 2005 | 02:22 PM
erexion's Avatar
I added about a 2 gallons or so...
i checked the spark plugs and there all working good. Ill check out the websites u guys gave me... thanks for the help
Old Mar 2, 2005 | 02:24 PM
88DXCRX's Avatar
Default Re: question...... (erexion)
When you turn on the key,
Does the check engine light come on?
If so,does it go out after a few seconds?
Old Mar 2, 2005 | 02:45 PM
Targa250R's Avatar
be professional
Can you hear the fuel pump turning on when you turn the key to position II ("on")?
Old Mar 2, 2005 | 04:25 PM
erexion's Avatar
I don't have my gauge cluster in right now because i am puttin indiglo gauges in at this time... I can hear the fuel pump turn on also. I think the problem is my spark plugs though.. i rechecked them and i noticed i have a lot oil in thier which i haven't seen as bad as this is.. so i think i might drain my oil and put new stuff in. Right now i am cleaning my spark plugs, hopefully it works.
steezychristian
Sep 18, 2011 09:46 AM
Yamaha798
Apr 5, 2005 08:43 AM
odishaw
Sep 25, 2004 04:45 PM
hatchy
Apr 3, 2003 06:50 PM
garagespecial
Jun 25, 2002 10:00 AM
