AC mount required for DOHC swap if no AC is to used?
Old Mar 2, 2005 | 01:54 PM
CaptivaBlue's Avatar
Default AC mount required for DOHC swap if no AC is to used?
I have a B16 that's going into my Z6 equipped Sol very soon. I feel like I have a good grasp on it all but until recently I was certain that the AC mount was only around to hold the AC compressor. Being that I have a Sol and AC makes me car sick anyways, I want to do away with it. There is no reason to have an AC mount, correct?
Old Mar 2, 2005 | 02:56 PM
del_orson's Avatar
Default Re: AC mount required for DOHC swap if no AC is to used? (CaptivaBlue)
I took mine off, you dont need it
Old Mar 2, 2005 | 05:08 PM
Hybrid96EK's Avatar
Default Re: AC mount required for DOHC swap if no AC is to used? (del_orson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">I took mine off, you dont need it</TD></TR></TABLE>
The mount itself is a torque mount and should not be removed completely. If you don't want to use the AC then it doesn't matter what mount you put in there (P72, P30, P54, P73). They will all serve thier purpose the same.
Old Mar 2, 2005 | 06:22 PM
VTECVillain's Avatar
Default Re: AC mount required for DOHC swap if no AC is to used? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">The mount itself is a torque mount and should not be removed completely. If you don't want to use the AC then it doesn't matter what mount you put in there (P72, P30, P54, P73). They will all serve thier purpose the same. </TD></TR></TABLE>
Agreed
Old Mar 3, 2005 | 08:54 AM
Turbo E's Avatar
wrong. you do need it. as stated already its a torque mount. just unbolt the AC compressor and you're done.
Old Mar 3, 2005 | 03:39 PM
Blue Hybrid's Avatar
yes, you DO need this mount as you notice there is one on the other side, and none on the front (like how the old single cams, or h22a's are)
forcfedcivic
Jun 30, 2015 03:31 AM
Mugen_DC2R
Sep 18, 2006 08:14 AM
jolt-tsp
Feb 24, 2004 01:14 PM
mingchi69
Aug 13, 2003 11:15 AM
