Radiator overflow tank....how NECESSARY is it?
Old Mar 2, 2005 | 12:11 PM
crexer's Avatar
Default Radiator overflow tank....how NECESSARY is it?
Cleaning up the engine bay a bit and the only thing that really stands out and is very ugly is the overflow tank with the line running to it from the top of the radiator. Have any of you guys just gotten rid of this thing or what? The fluid level in it never really changes so im just wondering if its really important.
Old Mar 2, 2005 | 12:17 PM
ELAMINT5's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (crexer)
I could be wrong but I alway thought it was for if you start to over heat the fluid has a place to go instead of blowing everywhere.
Old Mar 2, 2005 | 01:06 PM
crxnj's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (ELAMINT5)
My fathers car doesnt have one stock..And when the fans stopped working a while back it overheated and the coolant went everywhere..
You can always get a cylinder shape overflow tank and hide it,,They're all over ebay..Almost look like catchcans
Old Mar 2, 2005 | 03:20 PM
crexer's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (Mr.speaker)
any more opinions? I have a spoon 1.3 radiator cap, does this make any kind of difference if I wasnt using an overflow?
Old Mar 2, 2005 | 03:23 PM
kid-honda's Avatar
Mine is right inbetween the rad and unibody, its completely out of site but fully functional.
Old Mar 2, 2005 | 03:29 PM
Burlyirishdude's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (kid-honda)
that pic always make me wanna go and try to hide everything
Old Mar 2, 2005 | 03:49 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">Cleaning up the engine bay a bit and the only thing that really stands out and is very ugly is the overflow tank with the line running to it from the top of the radiator. Have any of you guys just gotten rid of this thing or what? The fluid level in it never really changes so im just wondering if its really important.</TD></TR></TABLE>
Yes it has to be there. THis is where the system releives excess pressure and coolant.
Old Mar 2, 2005 | 04:37 PM
ELAMINT5's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">Mine is right inbetween the rad and unibody, its completely out of site but fully functional.
once again your engine bay amazes me.
how much time it that take you? did you do with the motor out?
Old Mar 2, 2005 | 04:44 PM
Wes V's Avatar
You need the tank!
The reason is that the radiator cap is lower than some of the water passages within the head. So, you can't get all the air out by just filling the radiator.
What happens is that the air that is in the system works it's way out when it expands (due to heat) and blows out into the tank. When the system cools off, it sucks back fluid (that's why the tank draws from the bottom).
Wes
Old Mar 2, 2005 | 05:00 PM
krazie1's Avatar
BANNED
Default Re: Radiator overflow tank....how NECESSARY is it? (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">You need the tank!
Wes </TD></TR></TABLE>
correct that is why I didn't remove mine
just clean it or get a new one and it will look good
Old Mar 2, 2005 | 05:03 PM
illdb8's Avatar
I am forced to admit it is a VERY clean engine bay
Old Mar 2, 2005 | 05:16 PM
TIRENECK's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (wyomingcrx)
I wont denied it but yea im second to kid-honda, hahaha .
VRD^don's Avatar
you'll need one if your planing on running at the tracks or any events..
Old Mar 3, 2005 | 09:27 AM
kid-honda's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (sohc_Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">you'll need one if your planing on running at the tracks or any events..</TD></TR></TABLE>
They clean up real nice to, I was able to make mine look new even though you dont see it.
I did do with the motor in and everyother car I have done with the motor in also.
I spent 2-4 hours.
Old Mar 3, 2005 | 10:54 AM
sporkcrx's Avatar
Mine you can't even see through, it's COVERED with moldy **** on the inside...and impossible to clean off. I'm about to break down and buy a new one or use a gatorade bottle or something...anyone have any suggestions?
Old Mar 3, 2005 | 10:56 AM
sporkcrx's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (sporkcrx)
So it just lets air out into the resevoir, then takes a lil water on once all the air is out? I thought it constantly takes water in, and takes water out everytime you drive it?
Old Mar 3, 2005 | 10:59 AM
PRS395's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it has to be there. THis is where the system releives excess pressure and coolant. </TD></TR></TABLE>
What he says!
Old Mar 3, 2005 | 12:46 PM
ukdm crx's Avatar
Old Mar 3, 2005 | 12:57 PM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">So it just lets air out into the resevoir, then takes a lil water on once all the air is out? I thought it constantly takes water in, and takes water out everytime you drive it?</TD></TR></TABLE>
It will let air out of the system if you have rescently opened the cap...if not it only lets liquid in/out. That's why there is a tube from the top of the res to the bottom.
I removed my stock crappy 1000 sided coolant res and relocated a little smaller clear container to make room for my breather tank.
After a hard drive the tank is 3/4 full of liquid as the cooland has expanded in the system and pushed the rad cap to release some pressure.
After it cools down to room temp the tank is 1/4 full as the coolant has contracted and sucked back in ONLY LIQUID per the tube from top of tank to the bottom.
Cliffs notes: you need it.
Vince
Old Mar 3, 2005 | 01:13 PM
tommycrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Mine you can't even see through, it's COVERED with moldy **** on the inside...and impossible to clean off. I'm about to break down and buy a new one or use a gatorade bottle or something...anyone have any suggestions?</TD></TR></TABLE>
The dishwasher is your friend.
Old Mar 3, 2005 | 01:23 PM
kid-honda's Avatar
Default Re: Radiator overflow tank....how NECESSARY is it? (tommycrx)
I soak mine in simple green over night and use a bendable wire brush
Old Mar 3, 2005 | 03:05 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommycrx &raquo;</TD></TR><TR><TD CLASS="quote">
The dishwasher is your friend. </TD></TR></TABLE>
hahahaha, **** that! I'm a car guy and all, but I would never do that. I might try soaking it overnight.
Old Mar 3, 2005 | 03:40 PM
LSVTEC 91 Civic's Avatar
Banned
Old Mar 4, 2005 | 12:41 PM
Qfactor's Avatar
take it off and let us know when your engine overheats.
Old Mar 4, 2005 | 02:14 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Radiator overflow tank....how NECESSARY is it? (Qfactor)
i put my overflow in the front too
