FS: Pistons (ITR/CTR/P30/PR3) & King Bearings!
Old Mar 2, 2005 | 11:49 AM
thevanitygroup's Avatar
Default OUT OF STOCK... NO MORE PISTONS AVAILABLE!!
Modified by thevanitygroup at 10:06 PM 4/3/2005
Old Mar 2, 2005 | 12:17 PM
Default Re: >> !PISTONS! (ITR/CTR/P30/PR3) & King Bearings << (thevanitygroup)
Old Mar 2, 2005 | 10:00 PM
Default Re: >> !PISTONS! (thevanitygroup)
All PM's replied!
Modified by thevanitygroup at 7:17 PM 3/3/2005
Old Mar 2, 2005 | 10:05 PM
nub.96ek's Avatar
How long do the bearings last as opposed to oem? I've heard aftermarket bearings wear out quicker...
let me know
Old Mar 2, 2005 | 10:35 PM
Default Re: >> !PISTONS! (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">How long do the bearings last as opposed to oem? I've heard aftermarket bearings wear out quicker...
let me know</TD></TR></TABLE>
This is a unanswerable question. I mean it all depends on your driving habits, which oil you use, how the were installed... So many things. Typically because of the construction of this bearing, it should last as long if not longer than OEM considering it exceeds OEM specifications "BUT" some people swear by OEM. It's really up to you. I personally use these bearings and know people who have. Zero problems.
Old Mar 3, 2005 | 07:30 AM
Default Re: FS: Pistons (ITR/CTR/P30/PR3) & King Bearings! (thevanitygroup)
Modified by thevanitygroup at 8:16 AM 3/4/2005
Old Mar 3, 2005 | 06:17 PM
Default Re: FS: Pistons (thevanitygroup)
Old Mar 4, 2005 | 07:16 AM
Good morning!
Old Mar 4, 2005 | 03:57 PM
Home from work bump.
Old Mar 4, 2005 | 09:48 PM
Going to bed bump. Shipments go out tomorrow. Thanks everyone.
Old Mar 4, 2005 | 11:18 PM
Pictures added bump. Now im really going to sleep. All PM's replied.
Old Mar 5, 2005 | 05:57 AM
Wake up everybody. Time to go to work.
Old Mar 5, 2005 | 01:09 PM
JDMJNKY's Avatar
BUMP BUMP BUMP!!!(b2k)
Great items I just picked up all of these from this guy!!
USDM ITR OS Pistons & rings
King Bearings
Old Mar 5, 2005 | 02:21 PM
Default Re: (JDMJNKY)
Old Mar 5, 2005 | 07:59 PM
Default Re: (thevanitygroup)
All PM's replied. ZC P29 pistons added to stock.
Old Mar 6, 2005 | 11:04 AM
All PM's replied. Lots of questions on the 84's....
Old Mar 6, 2005 | 02:07 PM
Lunch bump.
Old Mar 6, 2005 | 06:13 PM
Dinner bump. PM's replied again.
Old Mar 6, 2005 | 06:43 PM
turbociv's Avatar
what kinda compression are we talking about with these 84.5 pistons??? or are they basicaly b20b/z pistons with stock low compression numbers.
Old Mar 6, 2005 | 08:38 PM
Default Re: (turbociv)
They are not basically B20 pistons. I can get CTR, ITR, P30 piston profiles in 84+ bore sizes. The C/R with the JDM ITR's it low 12's and with the USDM ITR's high 11's. Every other profile yields a much higher compression ratio. I usually only suggest the ITR's. If your running on 94 octane or race gas, then the P30's or CTR may suit you (13's and 15's C/R) BTW, PM's replied. Thanks for the overwelming response.
Old Mar 6, 2005 | 09:38 PM
RMS's Avatar
RMS
very interested in these for our customers. can you take a look at the 84mm with ctr profiles and see if the dome is solid (like topline's ITR replacements)? easy to modify cr with a lathe thanks
Old Mar 6, 2005 | 10:45 PM
Default Re: (RMS)
The are indeed solid. Very good idea because, obviously at 84mm a CTR pistons C/R is absolutly insane unless your on race gas 24/7 and run HD S200 or AEM EMS fully dyno tuned. The ITR's are actually very suiting daily driver replacements.
Old Mar 7, 2005 | 04:41 PM
84mm's are not for sale until a cheaper shipping arrangment can be provided. 81's still going like hot cakes.
Old Mar 7, 2005 | 08:21 PM
Nightly bump...
Old Mar 7, 2005 | 09:02 PM
ajzeg's Avatar
what would be the best out of what you carry to run in an ls vtec daily driver w/stock ls rods and new bearings
