K Series Header thread
Old Mar 2, 2005 | 10:28 AM
AllMTRWH0R3's Avatar
Default K Series Header thread
Hi since I am looking for a K series header for my k24/k20 searching is not easy on this site, as this thread is to be used to help others that may not be able to find info so easy.
DC tsx?
Hytech
DTR
ANR
SMSP?
If anyone has pics of the header please post them up as the thread can help people out.
Old Mar 2, 2005 | 10:30 AM
AllMotorMadness's Avatar
Default Re: K Series Header thread (allmtrwhore2)
K-Series Header = DTR all the way
Old Mar 2, 2005 | 10:38 AM
Supernatural's Avatar
http://www.dtr-fab.com/product....html
hope this helps
Old Mar 2, 2005 | 11:22 AM
HobbesGSR's Avatar
In what kind of car?
Old Mar 2, 2005 | 11:48 AM
Default Re: K Series Header thread (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">http://www.dtr-fab.com/product....html
hope this helps</TD></TR></TABLE>
Thanks for the shamless plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HobbesGSR &raquo;</TD></TR><TR><TD CLASS="quote">In what kind of car?</TD></TR></TABLE>
My car is a 92 hatch.
This should turn out to be a good thread.
Old Mar 2, 2005 | 01:24 PM
tONE.steR's Avatar
* B A N N E D *
Rcrew is a choice too.
Old Mar 2, 2005 | 03:12 PM
JV's Avatar
JV
Who?
Rcrew:
DTR:
True Race:
Old Mar 2, 2005 | 03:51 PM
shant's Avatar
Default Re: K Series Header thread (Underachiever)
DTR
Old Mar 2, 2005 | 03:55 PM
SiKnezzALLmotor's Avatar
Default Re: K Series Header thread (shant)
dtr and rcrew have great quality headers
Old Mar 2, 2005 | 04:16 PM
SuperTwinz's Avatar
https://honda-tech.com/zero...age=5
Old Mar 2, 2005 | 05:34 PM
RMF
Guest
Posts: n/a
Default Re: K Series Header thread (SuperTwinz)
http://www.importpowerhouse.co...s.htm
Old Mar 2, 2005 | 05:49 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: K Series Header thread (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">http://www.importpowerhouse.co...s.htm</TD></TR></TABLE>
I like the header up until the exit of the collector, looks like you're trying to give it a venturi effect?
Helping you out...
Old Mar 2, 2005 | 11:31 PM
RMF
Guest
Posts: n/a
Default Re: K Series Header thread (Vita-Soy)
Optical allusion .Yeah it does look kinda funny in the picture.But its like the other headers .That's a 1 3/4 merge with a 2" out to 2 1/2.The length is for around 5000 to 10,000rpm.Any shorter than that will be above A K-motors RPM range.
Old Mar 2, 2005 | 11:58 PM
tONE.steR's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Optical allusion .Yeah it does look kinda funny in the picture.But its like the other headers .That's a 1 3/4 merge with a 2" out to 2 1/2.The length is for around 5000 to 10,000rpm.Any shorter than that will be above A K-motors RPM range. </TD></TR></TABLE>
If i wanted 2.75" collector can you do that?
Old Mar 3, 2005 | 05:26 AM
Jon V's Avatar
1 3/4 is kinda small isn't it? how do you think this header would work on a K24 with tghe lower 6500-7000 Red line...
You got any better pictures?
Old Mar 3, 2005 | 06:36 AM
RMF
Guest
Posts: n/a
Money can get you almost anything you want.I will do a 6" collector. If your going to buy it.And the other guy.The ports on a K-series head are the same size as the inside of a 1 5/8 tube.So I ran 1 5/8 then stepped it to 1 3/4.Now if you have a K-24 and you made the ports bigger,And the head flowed more air.Then I would use a bigger size tube.
Maybe you don't understand how that works.If you have a head that flows say,280cfm .On a 1600cc motor right? Then you put that same head on a 6000cc motor .Its still going to flow 280cfm.
If you have a garden hose and the water is all the way on,And you put a bigger hose on the end of the other one .Is more water going to come out?
No its just going to take longer to fill the bigger hose up.
Old Mar 3, 2005 | 06:41 AM
CompressionFed's Avatar
Nice example!
*off topic, Randy I just received my B series header
Old Mar 4, 2005 | 10:34 AM
Jon V's Avatar
RMF have you ever done any TI work?
going to be putting a K24a2 in my EK and am looking at my options...
interested in header and exhaust...
Old Mar 4, 2005 | 05:27 PM
RMF
Guest
Posts: n/a
Default Re: K Series Header thread (Jon V)
Yes I have.About 15 years ago.I use to weld flight recorder boxes together,Inside a purge chamber.I welded 175 of them. So I guess I have a little experience.Why?
Old Mar 4, 2005 | 06:32 PM
k20GSR's Avatar
I think I will be buying the RMF header.
Old Mar 4, 2005 | 07:22 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Didn't realize your K header was posted on the site Randy.
Old Mar 4, 2005 | 07:32 PM
RMF
Guest
Posts: n/a
Default Re: K Series Header thread (rochesterricer)
DOH
Old Mar 5, 2005 | 03:02 AM
SEFIxCivic's Avatar
this is on 91 octane, K20A-R full exhaust, rcrew intake, rcrew pimp, rcrew header, and kpro tuned by me. this is exactly the same way it runs on the street. no dyno only hp tricks.
i have had people dyno here on my dynapak, and run on a dynojet... and thanks to Jeff Evan's advice on how to set the ramp rate... ours actually read lower.
Old Mar 5, 2005 | 06:20 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Yes I have.About 15 years ago.I use to weld flight recorder boxes together,Inside a purge chamber.I welded 175 of them. So I guess I have a little experience.Why?</TD></TR></TABLE>
TI exhaust, or/and header ? K24a2 EK
Old Mar 6, 2005 | 08:34 AM
redrum eg6's Avatar
true race makes nice stuff
the same fabricators make stuff for pro-mod drag cars.
