d16z6 swap in 89 hatch
Old Mar 2, 2005 | 09:51 AM
CivicManLs's Avatar
Default d16z6 swap in 89 hatch
I got the motor in, and everything is installed except for the obd0 wiring harness.
I also have an obd0 to obd1 conversion harness so I can use the p28 ecu.
The problem is that before my swap the car was dpfi, and the z6 is an mpfi motor. I also know that obd0 injectors will not work with an obd1 ecu so wiring dpfi to mpfi in obd0 is no good. How am I supposed to convert from dpfi to mpfi in obd1? Thanks
Old Mar 2, 2005 | 09:53 AM
riceisnicenv's Avatar
Default Re: d16z6 swap in 89 hatch (CivicManLs)
search on here and get the instructions to converting to MPFI... then follow the instructions to convert to OBD1. that should help you out some.
OemED
19
Oct 10, 2016 08:19 AM
gnccracer20
Feb 9, 2009 09:12 PM
brg2nr
Nov 2, 2005 03:07 PM
lazyboy
Oct 8, 2005 06:49 AM
G2integra217
May 8, 2005 11:39 PM
