B16 repair/maintence questions
Old Mar 2, 2005 | 09:00 AM
2.2XDreams's Avatar
Default B16 repair/maintence questions
Hey guys, my hatch has been giving me some problems lately and i need to get it fixed because i failed emissions this past week.
1. They said that the fuel is leaking which i didnt know about. so my question is what is the stock fuel pressure on a B16 suppose to be? because imagine there would be a drop in pressure if there is a leak.
2. How can i check to make sure that the TPS is still working correctly? can i just hook a voltmeter up to it? if so what numbers am i looking for?
3. It need a valve adjustment bad. so what does the valve lash need to be set to?
4. They also had a hard time keeping the car on the rollers, the guy there told me that my frame *might* be twisted. on average how much does it cost to have a frame examined and pulled if necessary?
Im just freaking out about this because i have expired tags on my car and i gotta get this fixed by the end of the month or im in trouble. Thanks Guys!
Old Mar 2, 2005 | 11:56 AM
screwmesa's Avatar
Default Re: B16 repair/maintence questions (2.2XDreams)
Intake feeler gauge specs: .006-.007
Exhaust feeler gauge specs: .007-.008
tps - unplug it while its running, if it doesnt bog or die its broken.
Old Mar 2, 2005 | 12:03 PM
crxtreme89h's Avatar
Default Re: B16 repair/maintence questions (screwmesa)
Ummm.....I don't know about unplugging the TPS while the car is running. That doesn't sound like a good idea to me. You could cause the motor to rev up all of the way and damage something. Maybe I am wrong, but I would get a 3rd opinion on this before you try.
Old Mar 2, 2005 | 04:25 PM
2.2XDreams's Avatar
Default Re: B16 repair/maintence questions (crxtreme89h)
anybody got an opinion on this? what about the other stuff?
Old Mar 2, 2005 | 06:22 PM
N1ghtM0nkey's Avatar
My car actually goes in tomorrow morning to have the frame pulled straight. It's going to cost me $160 and the turn around time will be one day.
Old Mar 2, 2005 | 06:31 PM
civicflow's Avatar
Default Re: B16 repair/maintence questions (N1ghtM0nkey)
if you test the TPS with a voltmeter it should be 0.5v closed throttle and 4.5v open throttle
Old Mar 2, 2005 | 06:45 PM
2.2XDreams's Avatar
Default Re: B16 repair/maintence questions (civicflow)
what about the fuel pressure thing? if it helps i believe that the car is running off of a 90 STD fuel pump.
crick_james
Jun 7, 2008 07:11 PM
Turbo_Mike
Feb 5, 2008 08:15 PM
Cidone
Feb 25, 2007 05:58 PM
chirp2hrd
Sep 3, 2002 03:47 PM
FUP23
Jul 2, 2002 11:21 PM
