whcih valvetrain is better for a lsvtec not reving past 7200
Which one people? Take into consideration that I am using stock ctr cams.
From now on I want to exclude the jdm itr valvatrain. So vote from rocket motorsports and down
Modified by alloysr16s at 6:15 PM 3/3/2005
Modified by alloysr16s at 4:12 PM 3/4/2005
ITRs should be just fine. Which cams do you plan on using? If you're just using stock B16/GSR cams the GSR valvetrain will work fine as well.
7200 RPM is not alot. you can run any stock valvetrain and you should be fine.
If you're using higher lift cams, you'll be revving higher anyway and that will require aftermarket valvetrain
My opinion is that stock valvetrain should NEVER be used for any perf. app. regardless of your fuel cut-off. There is NO safety margin.
Mis-shifts (mechanical over-rev's) don't abide by the fuel cutt off point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">My opinion is that stock valvetrain should NEVER be used for any perf. app. regardless of your fuel cut-off. There is NO safety margin.
I agree that in perf. applic. that valvetrain should be upgraded.
But in this case 7200 is even way below stock rev limit. I dont see why stock valvetrain is not sufficient enough.
Mis-shifts (mechanical over-rev's) don't abide by the fuel cutt off point.</TD></TR></TABLE>
If this was the case, then even stock cars should have upgraded valvetrain.
They should have upgraded valvetrain.
Just like they should have upgraded clutches.
These are the week points of the all OE set-ups.
You wanna do a 3rd to 2nd but meant to go to 4th gear mis-shift with stock springs?
Also rev limit is not the only thing to look at. More HP per cylinder will require more spring.
GURU TIME
As a cylinder fires, does the crank speed up? If it fires harder will it speed up faster? And if the crank accelerates faster will the cams accelerate faster?
Does lightening the flywheel and main pulley affect this.
Hmm. Very important things to ponder about for 5 mins.
More fun terminology
1) Position
2) Speed 1st derivateve of postion / time
3) Acceleration 2nd derivative of position / time
3) Jerk 3rd derivative of position / time
4) Snap 4th derivative of postion / time
Things to think about for a couple of years.
GURU TIME
1) Position
Of course its always a good point to upgrade valvetrain in any performance application.
If a guy came to our shop and wanted an intake and exhaust. and he plans to jus have a fast performing street car with those bolt ons. I'm not going to immediately say you have to upgrade valvetrain, rod bolts, Motec engine management, sleeve the block, get better rods, etc.
What I'm trying to say is it all depends on what you are planning to use the car for.
I was assuming the setup isnt planned for high hp, high stress racing situations. its only to 7200rpm.
I understand you Robert, If customers had endless pockets, then I would highly recommend certain things so they can complete their setup. Even if they dont, I would give some recommendations for certain upgrades to help strengten the motor.
If I did that to everyone, they'll all be scared to fix up their car since alot of things have to be done. heheh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">How much is the going rate to for springs and installation of springs while the motor is in the car?</TD></TR></TABLE>
We wont even do it that way.
but then again, we dont work on cars anymore.
What is the difference between the Gen 1 and 2 . I am using Ctr cams. It doesnt matter price because they cost the same ( from what someone offered me)
I got an offer of 238.99 shipped of gen 1 or 2 springs and retainers. Is there anyone who can beat that
G1 springs have 95lbs on the seat and 265 at 0.500" lift
G2 springs have 55lbs on the seat and 185lbs at 0.500 lift.
I would do the G2 springs for CTR cams.
littlegreenb18
33
Jan 23, 2006 03:58 PM
tegsallgood
Nov 11, 2004 11:00 PM
