Clutch rebuild question
Old Mar 2, 2005 | 05:33 AM
hondacivic_si's Avatar
Default Clutch rebuild question
My clutch is going, and very soon, so it has to get replace, Me and some people I know are going to be doing it this weekend, but I need to know what I need, just the Clutch Disc, or would I need the Clutch Set- Matched, i'm getting them from Autozone.
any help/feedback is great!
Old Mar 2, 2005 | 05:41 AM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: Clutch rebuild question (hondacivic_si)
You'll need a new clutch disc and pressure plate. Also you should re-surface your flywheel.
Old Mar 2, 2005 | 05:43 AM
Default Re: Clutch rebuild question (HalfAnP)
ok, so $70 for clutch disc, and another $65 for the pressure plate, would it be better just to get the clutch set- matched?
CLUTCH SET-MATCHED for a
1993 HONDA CIVIC
$114.99
CONTAINS PREMIUM FRICTION, O.E. MANUFACTURED CLUTCH
COMPONENTS, LIFETIME WARRANTY
Old Mar 2, 2005 | 05:49 AM
civic-si-2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic_si &raquo;</TD></TR><TR><TD CLASS="quote">ok, so $70 for clutch disc, and another $65 for the pressure plate, would it be better just to get the clutch set- matched?
1993 HONDA CIVIC
$114.99
COMPONENTS, LIFETIME WARRANTY</TD></TR></TABLE>
Yes that would be better. At my job (acura dealer) we replace the clutch, flywheel, pressure plate, and the throwout bearing. Its expensive but I'm a do it right the first time guy. Good luck. Be careful with that slave cylinder. Nothing strips faster than that 10mm brake line. Also don't forget to lubricate the rod on the slave cylinder or it will squeek. Happened to me.
Old Mar 2, 2005 | 05:51 AM
Default Re: Clutch rebuild question (civic-si-2000)
Ok, so everything i'll need will be in the clutch set, correct? If so, i'm going to go out and get it today
eK9aT10pSi's Avatar
permetex white lithium grease, be liberal on the inside of the thorw out bearing, the shift fork where it rests on the nipple and the part with the slave cylinder pushes out the piston onto the fork.
Old Mar 2, 2005 | 05:58 AM
EE_Chris's Avatar
Default Re: Clutch rebuild question (eK9aT10pSi)
Is white lithium really the grease you wanna use here??
Helms calls for some "high temp urea" grease but if this matches the functionality of the white lithium, then cool.
Aside from the kit containing the clutch disk, pressure plate, throw out bearing and pilot bearing, hopefully it will also come with the clutch alignment tool too.
And get your flywheel resurfaced. I did a clutch job on my stock Y7 and didn't resurface the wheel - its biting me in the *** now.
Old Mar 2, 2005 | 06:26 AM
everlasting1832's Avatar
why dont you just get the whole clutch kit. they got tons of cheap clutch kits all over ebaymotors.com and also dont forget to resurface your flywheel!!
Old Mar 2, 2005 | 06:29 AM
Default Re: Clutch rebuild question (everlasting1832)
Where would I get my flywheel resurfaced?
Old Mar 2, 2005 | 07:27 AM
EE_Chris's Avatar
Start by calling a local fix-it shop. If they can't do it, chances are high that they probably know someone who can.
Old Mar 2, 2005 | 07:28 AM
Default Re: Clutch rebuild question (EE_Chris)
Ok, I called our local CarQuest shop, $45 at the most, so I figure that thats not to bad.
Old Mar 2, 2005 | 07:29 AM
EE_Chris's Avatar
You may be able find it a bit cheaper if you look around a little more - but thats not unreasonable.
Old Mar 2, 2005 | 07:46 AM
good idea, i'll do that before I get it done
Old Mar 2, 2005 | 07:48 AM
spoonek9's Avatar
http://www.clutchcityonline.com/honda_civic.htm
Old Mar 2, 2005 | 07:55 AM
Default Re: Clutch rebuild question (spoonek9)
thats a good deal, but they don't have what I need
I have an SI 1993
Old Mar 2, 2005 | 08:13 AM
sinolimitssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes that would be better. At my job (acura dealer) we replace the clutch, flywheel, pressure plate, and the throwout bearing. Its expensive but I'm a do it right the first time guy. Good luck. Be careful with that slave cylinder. Nothing strips faster than that 10mm brake line. Also don't forget to lubricate the rod on the slave cylinder or it will squeek. Happened to me.</TD></TR></TABLE>
My car is starting to squeek. 99si.. DRIVES ME NUTS!!! My clutch works fine but im thinking about upgrading the cluth. then get rid of that damn squeek. Squeek:
Old Mar 2, 2005 | 08:33 AM
spoonek9's Avatar
92-00 1.6L - kit# 08-022
Old Mar 2, 2005 | 08:36 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic_si &raquo;</TD></TR><TR><TD CLASS="quote">I have an SI 1993 </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">92-00 1.6L - kit# 08-022</TD></TR></TABLE>
"Except Si series"
Unless thats a typo on their website...
Old Mar 2, 2005 | 09:06 AM
spoonek9's Avatar
They mean the B series "SI".
Old Mar 2, 2005 | 10:42 AM
The grease we use is Honda high temp urea grease. Some sil-glyde would work too.
Old Mar 2, 2005 | 11:06 AM
SOHCEK-Turbo's Avatar
All 92-00 SOHC Civic clutches should all work SI or not. I would order the one from clutch city they have great prices. Yup I am sure they mean B series SI.
Old Mar 2, 2005 | 11:42 AM
gunnis's Avatar
Default Re: Clutch rebuild question (EKSOHCV-TechRider)
A heads up because i ran into this problem in the middle of my first clutch replacement, just a few things you will need,and i hope i remember sizes correctly.
You will need a 12 point, 10 mm socket to remove the pressure plate bolts
and as well a 12 point 17 to 19mm socket to get the flywheel off. i forget what size exactly maybe pick up all three if you can they are pretty cheap, or somebody might chime in.
Good luck
Old Mar 2, 2005 | 12:14 PM
Default Re: Clutch rebuild question (gunnis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnis &raquo;</TD></TR><TR><TD CLASS="quote">A heads up because i ran into this problem in the middle of my first clutch replacement, just a few things you will need,and i hope i remember sizes correctly.
Good luck</TD></TR></TABLE>
yes and make sure you use a 10mm line wrench for the slave cylinder. If not you will round it off. And it is a 12 point 17mm on the flywheel.
Old Mar 2, 2005 | 01:18 PM
gunnis's Avatar
yes and make sure you use a 10mm line wrench for the slave cylinder. If not you will round it off. And it is a 12 point 17mm on the flywheel.</TD></TR></TABLE>
Thanx for clearing up that it is in fact 17mm. And yes i forgot the 10 mm flared nut wrench.
Old Mar 2, 2005 | 01:24 PM
eK9aT10pSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Is white lithium really the grease you wanna use here??</TD></TR></TABLE>
yeah, ive used that in all the cars ive done, works very well. keeps that **** lubricated, no squeeks
