jdm itr swaybars
Im swaping out the rear swaybar on my 99 gsr for the 23mm jdm itr bar. Is there anything else i will need other than the 23mm bushings, the 23mm swaybar, and the beaks kit? Because i am going to use the jdm itr rear swaybar i decided to buy the jdm itr front swaybar as well. Password:jdm sells the front swaybar, but is there anything else i need to get it installed like different bushings or hardware?
Thanks
Thanks
you need the end link bushings for the sway bar, but the inside collar will work from the old sway bar.
Why get the front. From what i understand the fron on the GSR and ITR are the same, and even if it is bigger it will basically cancel out the efect of the larger rear sway bar. Do a search about this. I am just saying what i can remember, but i know there are some great posts on the advantage/disadvantage of the larger front sway bar
redeyz, you can go to my website at http://www.geocities.com/bretq....html or http://www.geocities.com/bretq....html for a complete parts list and step-by-step instruction for installing the 22mm or 23mm Type-R rear swaybar.
Racermech, the 98+ JDM Integra Type-R uses a 23mm rear swaybar and a 25mm front swaybar (which is 1mm larger than the GS-R and USDM Type-R).
I was planning on installing the front sway in addition to the 23mm rear because from what i have read here on HT, the general consensus seems to be that the jdm itr 23mm rear sway is too large without stepping up the front as well. BSQ, thanks for your help. Your site is by far the best when it comes to sway bar installs. Do you or anyone else know what all i will need for the front sway? Thanks again guys.
redeyz, what was or will be included with the JDM front swaybar (ie. swaybar only, swaybar and bushings, etc.)? This will help determine what else will be required. Also, what model Integra will it be installed on? The reason I ask, is because the GS-R and Type-R use different endlinks for the front swaybar than the other Inegra models.
BSQ, im not exactly sure what is included with the front swaybar. I believe the bushings are included, but i assume this only because of the picture password:jdm includes. They don't describe or list anything about the product other than that its a jdm itr front swaybar. here is the link http://passwordjdm.com/product...D=216. I am trying to figure out if this will do the job. Thanks again bsq for all your help. Also these sways are being installed on my '99 gsr.
redeyz, the picture of the JDM ITR front swaybar on password:jdm's website is actually the ITR rear swaybar. More than likely password:jdm will include the swaybar bushings with the bar. Since you have a GS-R, the front swaybar will bolt right up with no other parts required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeyz »</TD></TR><TR><TD CLASS="quote">BSQ, you really are the man when it comes to swaybars
. Thanks again for all your help and advice with this project. </TD></TR></TABLE>
If hes the man why didnt you get his kit instead of beaks
. Thanks again for all your help and advice with this project. </TD></TR></TABLE>If hes the man why didnt you get his kit instead of beaks
