startin prob
Old Mar 1, 2005 | 09:47 PM
crexSIvtec's Avatar
Default startin prob
my car has had starting problems so i started taking steps into replacing things that could contribute to it, i've replaced EVERYTHING with OEM parts from Honda, distributer, plugs, plug wires, fuel pump, main relay, battery so on and so forth, when i turn the key to the on position the fuel pump never came on, now that i have replaced the main relay and the fuel pump there is still no result, the motor isn't blown, it cranks and turns over freely..... what could be the cause for my fuel pump not to come on, oh and i've tryed using 4 diferent ecu's...any help would be appreciated
Old Mar 1, 2005 | 11:56 PM
Redline130's Avatar
Default Re: startin prob (crexSIvtec)
Check the wiring going to the pump. Are you getting fuel to the fuel rail?
Old Mar 2, 2005 | 08:28 AM
EP3_05's Avatar
Default Re: startin prob (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Check the wiring going to the pump. Are you getting fuel to the fuel rail? </TD></TR></TABLE>
Ditto. Make sure the fuel pump is getting the fuel to the rail. Once that is verified make sure you are getting spark and then check the timing...both cam and ignition.
Old Mar 2, 2005 | 04:33 PM
crexSIvtec's Avatar
Default Re: startin prob (91civic)
the pump wiring is ok cuz i remember when i put in the new pump it could only go one way cuz the negative terminal is smaller than the posotive so the wires would only fit one way and no i'm not getting fuel to the fuel rail cuz the pump never turns on....the spark and timing are both set cuz i get spark and i did the timing so it's set......
Old Mar 4, 2005 | 09:24 AM
crexSIvtec's Avatar
ayn help??
Old Mar 4, 2005 | 07:54 PM
crexSIvtec's Avatar
any other suggestions ppl??????
Old Mar 4, 2005 | 07:59 PM
HatchBox's Avatar
Skoobie no more...
fuses?
Go out and buy a wiring diagram - see if the hot wire coming to the fuel pump is getting power. if it isnt see if the same wire gets power at the main relay, if i doesnt there then see if it is getting it from the ecu.
Old Mar 4, 2005 | 11:15 PM
crexSIvtec's Avatar
Default Re: startin prob (HatchBox)
thx i will try that out when i next get the chance and post a result.....i will still take more suggestions on what could be wrong, also anyone know what i should expect in a 1/4 mile with a JDM D16ZC(sohc vtec) with i/h/e and stage 2 exedy clutch in a 91 CRX HF...
Old Mar 5, 2005 | 05:10 AM
1RMDave's Avatar
try running direct power to the pump...just to see if it does work. If it does then its a problem somewhere between the ecu, relay, and pump. I hate to mess with wiring.....but maybe you could run the wires yourself and then work the pump off a switch...which also works nice as theft prevention.
nafreak
Mar 21, 2007 07:39 PM
Cameron60
Jan 16, 2007 06:04 PM
charlee
Dec 6, 2006 09:09 AM
crazygerman
Mar 4, 2006 11:57 AM
tegturbo
Aug 11, 2005 04:18 PM
