d16z6 throttle body and distributor on b18a
will a throttle body from my 93 ex fit the b18a manifold and and i stick all my sensors on it and also can i use the shoc distributor on the ls head
no the throttle body bolts are different on the old b18's than on hte new ones, if u had a b18b it would work, but im pretty sure the bolt pattern is a little different, the ex has a wider pattern
