NSX brake calipers/corrado rotors/EX spindles?
Old Mar 1, 2005 | 09:04 PM
xci_ed6's Avatar
Default NSX brake calipers/corrado rotors/EX spindles?
i remember seeing that this MAY work...any confirmation?
I have EX spindles, and can get Corrado rotors from my friend with a corrado (junk, but good for mock up). I just dont want to throw down $200ish for NSX calipers if I dont know if it will fit.
Old Mar 1, 2005 | 09:21 PM
crxgator's Avatar
Default Re: NSX brake calipers/corrado rotors/EX spindles? (krustindumm)
nsx calipers/brackets and prelude vtec rotors redrilled is what you need...
Old Mar 1, 2005 | 09:26 PM
njn63's Avatar
correct me if i'm wrong, but Prelude rotors are 11" and so are Corrado's. Corrado's just happen to have a 4x100 bolt circle which is what our cars have...
And i'm also interested in the NSX caliper idea so what is needed? EX spindles, nsx calipers/brackets and corrado rotors?
Old Mar 1, 2005 | 09:36 PM
crxgator's Avatar
Default Re: (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, but Prelude rotors are 11" and so are Corrado's. Corrado's just happen to have a 4x100 bolt circle which is what our cars have...
And i'm also interested in the NSX caliper idea so what is needed? EX spindles, nsx calipers/brackets and corrado rotors?</TD></TR></TABLE>
but the corrado rotors are a different offset and hub bore size...
if you guys do a search for this in the integra section, you will see what to use...
Old Mar 1, 2005 | 09:37 PM
Magick211's Avatar
Default Re: (njn63)
Hmm interesting topic the is the first time i have heard about corrado rotors. i may have to look into it
oops posted the same time as crxgator. so i guess corrado rotors are out of question
crxgator's Avatar
Default Re: (Magick211)
https://honda-tech.com/zerothread?id=1058427
Old Mar 1, 2005 | 10:02 PM
xci_ed6's Avatar
Default Re: (crxgator)
nice save gator!
so the integra spindle is the exact same as the EX spindle as far as brake positions go?
Old Mar 1, 2005 | 10:04 PM
crxgator's Avatar
Default Re: (krustindumm)
yes
Jonathan_ED3's Avatar
yes
dr_latino999
Suspension & Brakes
Mar 15, 2010 05:59 AM
jdm_dc_fan
Suspension & Brakes
Aug 17, 2007 10:21 PM
GoldenONE
May 16, 2003 11:43 PM
skunky
Jun 15, 2002 08:10 AM
B18C-EJ1
Dec 17, 2001 01:59 PM
