can i run a obd-1 dizzy on my obd-0 dohc zc?
Old Mar 1, 2005 | 07:25 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default can i run a obd-1 dizzy on my obd-0 dohc zc?
i need to know if i can do this cuz i am getting a diffent ecu made for when i put my turbo on and the ecu has to be a obd-1 so to change it over i need a 0bd-1 dizzy and the obd-0 to obd-1 harness
Old Mar 1, 2005 | 07:32 PM
jlicrx's Avatar
Default Re: can i run a obd-1 dizzy on my obd-0 dohc zc? (crxzcracer)
yes - although finding OBD1 DOHC ZC distributor may be tough (unless you get a new one from Distributor King) - you will need to get rid of the Cylinder Position Sensor on the end of the exhaust camshaft and do some rewiring - the OBD1 DOHC ZC has the CPS inside the distributor - get a plug from B18A1 to seal hole where CPS was
Old Mar 1, 2005 | 07:35 PM
crxzcracer's Avatar
Default Re: can i run a obd-1 dizzy on my obd-0 dohc zc? (jlicrx)
THANK YOU !!!!!!!!!!!!!!!!!!!!!
I am sooooo happy the answer is yes i am getting a great deal on this ecu!
Old Mar 1, 2005 | 07:38 PM
jlicrx's Avatar
i edited the post about the same time you were answering
Old Mar 1, 2005 | 08:54 PM
crxzcracer's Avatar
cant i just unplug the cps and run the wires to the dizzy or do i have to replace it? and do i run the wires to the dizzy or what?
Old Mar 2, 2005 | 01:14 PM
crxzcracer's Avatar
bump
Old Mar 2, 2005 | 03:39 PM
NikoZai's Avatar
Rywire.com sells the distributor adapter for the ZC (obd1 too)
We can also do all the wiring for your swap if you haven't done it yet.
We sell the JKOBD OBD0 to OBD1 Jumper harness with our swap packages.
peter@rywire.com
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
hudson13
Dec 10, 2010 04:54 AM
theidealone
Apr 14, 2008 06:21 PM
97grnrs
Dec 10, 2006 04:14 PM
Angry
May 5, 2006 08:58 AM
