Timing Question for b-motor
How do you check your timing with that gsr? I know you need the timing gun but the manual say to remove the check connector for the holder. With the ignition off, connect the two terminals together with a jumper wire. Thats from the haynes manual for honda 96-00,interga 94-00.
Now b/c the motor is in a crx, do i do that terminal thing for the crx or no? B/c my car is running rich and the riding rough. Also the one of my spark plug had a preignition in the first chamber (thats the one next to the timing belt)((right?)) Thanks -Phil-
Also-The motor is a b16a2 with a Gsr head-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyKoreanCrx »</TD></TR><TR><TD CLASS="quote">Now b/c the motor is in a crx, do i do that terminal thing for the crx or no?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyKoreanCrx »</TD></TR><TR><TD CLASS="quote">Also the one of my spark plug had a preignition in the first chamber (thats the one next to the timing belt)((right?))</TD></TR></TABLE>
right
yes
right
yeah your still need to do that. if you have an 88 your connector is in the engine bay behind the drivers headlight. in plain view. 89-91 is is near the ecu. It is behind the vynil kick panel on the side to the left of the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efcivic757 »</TD></TR><TR><TD CLASS="quote">yeah your still need to do that. if you have an 88 your connector is in the engine bay behind the drivers headlight. in plain view. 89-91 is is near the ecu. It is behind the vynil kick panel on the side to the left of the ecu.</TD></TR></TABLE>
Actually I have a 89 crx hf and its located in the engine bay near the driver headlight. Thanks for the info. Also not tryin to sound like an ***.
