Want to turbo my snowmobile
Old Mar 1, 2005 | 06:24 PM
240sx crazy's Avatar
Default turboing my snowmobile
Anyone know where i could find a turbo small enough to turbo a snowmobile? I have a 1999 arctic cat snowmobile with a 794cc displacment and puts 104hp to the track. Here are just some basic pics of it i took from my cell phone
Old Mar 1, 2005 | 07:51 PM
Kendall's Avatar
Look at some of the tiny *** turbo's that VW uses on things like the Jetta TDI.
Old Mar 1, 2005 | 08:35 PM
Default Re: (Kendall)
Do u know the exact name and type of turbo it is so it is easier for me to find.
Old Mar 1, 2005 | 08:40 PM
Kendall's Avatar
No I don't, but I've seen a couple of them and they are indeed tiny. Also, consider a turbo from a sportbike turbo kit.
Old Mar 1, 2005 | 09:19 PM
ridexstraight's Avatar
vw turbos are usaly ko3s, there pretty smal and mite work, or u could try a 9g(one of the tt off a vr4)
Old Mar 2, 2005 | 06:39 AM
dwnthehatch's Avatar
Default Re: (ridexstraight)
Get a turbo from a Honda Auquatrax R-12X.
Old Mar 2, 2005 | 07:06 AM
junkyard racer's Avatar
Default Re: (dwnthehatch)
the tdi turbo might not be a good choice, but you could pretty much use any small turbo, probably have to make your own mani, but no big deal. another thing to think about...fuel management.
this would be bad *** if you could complete it, but it would take alot of thinking...
Old Mar 2, 2005 | 07:37 AM
GDM Z28's Avatar
Default Re: (junkyard racer)
talk to cody (tinker) (aka lovefab) he makes manifolds for the snow mobiles so im sure he will know what turbo is best...
Old Mar 2, 2005 | 02:07 PM
Default Re: (civicflnum1)
I would be doing a turbo kit on a car but sense im not 16 till may i thought this would be a good project to keep me busy and give me some experience in this kind of thing. So yea about that manifold u think i would be able to build it myself or could i get it pre fabricated?
Old Mar 2, 2005 | 03:36 PM
NJIN BUILDR's Avatar
Default Re: (240sx crazy)
Find a snowmobile forum.People have been doing it for twenty years.An engine shop I worked at made and sold kits fifteen years ago.You loose some of the tuning effects of expansion chambers,but the make some serious top end.
Glenn
Old Mar 2, 2005 | 07:35 PM
Default Re: (NJIN BUILDR)
As it is at some of the long back straight aways at green water i have gotten it into the 120ish area but i would like to see it hit the very edge of the speedometer which is listed at 150 but i think that just mite be out of reach.
Old Mar 2, 2005 | 10:14 PM
rocketfuelcerx's Avatar
IS tha kilometer per hour or MPH... snowmobiles are ill..I almost flew off a mountain in Tahoe on one of those things... I vowed never to mash on one of those again...it just isn't worth it...
Old Mar 3, 2005 | 04:39 AM
jdmturbosol's Avatar
Default Re: turboing my snowmobile (240sx crazy)
The Arctic Cat T660 came with a turbo and it looks very familiar to a mitsubishi turbo. I could get you one brand new if you wanted but they are quite pricey.
Old Mar 3, 2005 | 06:35 PM
Default Re: (rocketfuelcerx)
Believe it not mph my dad has had it the sleeves ported which helps the top end by a few mph's and i have a larger than stock pipe that has a little less back presure which doesnt kill the low end to much and helps a ton on the top.
Old Mar 9, 2005 | 08:04 PM
xboostin4funx's Avatar
there are a few guys in my area with turbo sleds, they all seem to be using the same turbo setup, ill try to talk to them this week sometime to see what it is, but the set up consists of a turbo that has no wastegate or bov. the way that pressure is controlled is by the fans moving different angles front to back of the compressor and the wheel itself turns, and changes angles. the inside of the turbo housing has mulitple runners to regulate boost. this turbo can be tunned for very small motors or small displacment car motors. the only problem with these turbos are the price... very expensive but effective ill try to get a name of the company this weekend real cool and super fast
idpihb-teg
Feb 14, 2007 07:18 AM
Jasz
Mar 7, 2005 05:50 AM
typeRSXS
Oct 3, 2003 07:25 AM
