Honda Accord EX missing on one cylinder at idle only
Old Mar 1, 2005 | 06:21 PM
jjh3's Avatar
Default Honda Accord EX missing on one cylinder at idle only
1992 Honda Accord EX with 220,000 miles..........idles really rough all of a sudden. Pulled the plug wires one at a time.....all slow the engine except the one closest to the timing belt cover, although I could hear the spark firing from the wire. Swapped spark plugs, but same cylinder missing. Fine above about 1100 rpm's. I'm thinking maybe the injector, but would it run ok at speed? what am I missing?
Old Mar 1, 2005 | 06:57 PM
hondadude's Avatar
Default Re: Honda Accord EX missing on one cylinder at idle only (jjh3)
Do you have a spare plug wire laying around to try, that might be the first thing to do. If thats not the problem, I'd check for a too tight valve adjustment and then a compression check.
Old Mar 1, 2005 | 09:24 PM
vizion22's Avatar
Default Re: Honda Accord EX missing on one cylinder at idle only (hondadude)
i think i have the same problem as you..my idle is really loud and i cant figure out why..is this due to misfiring cylinders? Mine is not only in idle but when i drive to...sorry for hi-jackin thread.
Old Mar 2, 2005 | 04:35 PM
jjh3's Avatar
this is to hondadude mainly.......sorry, I did try a different spark plug wire with no change.....valves have never been adjusted, but remember, this was a sudden change.....ran fine only days ago, so I doubt if the valve clearance changed. also, compression was 150 psi. what happens when 1 injector stops working??
Old Mar 4, 2005 | 07:43 AM
Rad Racing's Avatar
Bart Taylor Look-alike
If the plug and plug wires are fine and you pull the wire and it does nothing, it's probably a bad injector. With that many miles I'd try getting all new ones if you plan to keep that motor for a while.
Old Mar 6, 2005 | 07:40 PM
jamey220's Avatar
Default Re: Honda Accord EX missing on one cylinder at idle only (Rad Racing)
i did a motor swap for one of my buddies in his 95 accord he went from non vtec to vtec and when i started the engine up is was running kinda ruff, i pulled the #1 plug wire and was not firing at all so i changed the distributor and the #1 plug started firing.
Old Mar 6, 2005 | 08:56 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rad Racing &raquo;</TD></TR><TR><TD CLASS="quote">If the plug and plug wires are fine and you pull the wire and it does nothing, it's probably a bad injector. With that many miles I'd try getting all new ones if you plan to keep that motor for a while.</TD></TR></TABLE>
doubtful but maybe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjh3 &raquo;</TD></TR><TR><TD CLASS="quote"> Pulled the plug wires one at a time.....all slow the engine except the one closest to the timing belt cover </TD></TR></TABLE>
This leads me to believe its definately electrical. Potentially the dizzy.
civicsir94
Apr 2, 2009 05:04 PM
ColfaxMax
Nov 17, 2004 07:19 AM
StRacer
Aug 10, 2003 09:27 PM
dbman96
Oct 16, 2002 03:54 PM
_Endless_
Aug 16, 2002 11:42 PM
