Rings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic »</TD></TR><TR><TD CLASS="quote">the Bearings are diffrent, each block has it's own code for witch bearing each main takes.</TD></TR></TABLE>
But most B series bearings are also interchangable and I believe some are made of better compounds than others.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neogenesis2004 »</TD></TR><TR><TD CLASS="quote">all b series mains are the same. b16/ls rod bearings are the same, while gsr/its rod bearings are the same. IE mains the same, rod bearins different on some engines.</TD></TR></TABLE>
No you are right and wrong all b series mains are the same yes but each block has it's bearing color code for clearence perposes you can buy just one set and put it in the block but chances are your oil clearence will be off witch in turn will shorten the life of the motor.
b18c5_ej8
Nov 26, 2011 05:07 PM
Justin Jones
K Series
Dec 31, 2010 04:22 PM
