f/hybrid
Old Mar 1, 2005 | 05:58 PM
v-6 hatch's Avatar
Default f/hybrid
so has any one done this setup..
f23 crank
f20c pistons
h23 block
h22 head?
is it possible what kind of machine work would need to be done... give me the good stuff
Old Mar 1, 2005 | 06:12 PM
SuperSlow's Avatar
Default Re: f/hybrid (v-6 hatch)
Did not think that S2k pistons were the right bore to work on a H23 block....
Old Mar 1, 2005 | 06:20 PM
v-6 hatch's Avatar
Default Re: f/hybrid (SuperSlow)
it was just a thought in my head.... whats the bore on those?
Old Mar 1, 2005 | 06:27 PM
v-6 hatch's Avatar
they are both 87 mm right?
Old Mar 1, 2005 | 06:48 PM
SuperSlow's Avatar
H series yes. F series... I thought it was 85.
Old Mar 1, 2005 | 06:57 PM
v-6 hatch's Avatar
huh ... maybe it it is .... i dunno mcuh about those f20z but i swore they were 87 mm
Old Mar 1, 2005 | 07:00 PM
civdx94's Avatar
i don t understand why everyone insists on using the f23 crank. ever seen the rods and rod journals? the f20c pistons will have a lower compression height and more than likely a differently a different pin size. pistons will sit to far in the hole and will cause a loss of compression obviously. in my opinion not really a good option for a build
Old Mar 1, 2005 | 07:28 PM
v-6 hatch's Avatar
Default Re: f/hybrid (civdx94)
well what about the f20c crank ?
i dunno uch about h/f
i am the farist from that right now building a d
Old Mar 1, 2005 | 07:48 PM
SuperSlow's Avatar
f20c crank will destroke your h23 block.... might as well just pick up an f20b motor, bore it and end up with better numbers and reliability...
Old Mar 1, 2005 | 08:09 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">f20c crank will destroke your h23 block....</TD></TR></TABLE>
Yes, not to mention the F20C uses a timing chain as opposed to a belt. With some machine work it could be done, but personally I'd rather use a K24 crank if I was going to go through all of that drama.
REDLUDE4WS
Oct 29, 2012 04:44 PM
REDLUDE4WS
Feb 21, 2011 12:25 PM
mightymaxgst
Jun 13, 2009 12:06 AM
h22_SOL
18
Sep 11, 2007 06:16 PM
crazykid
Jul 25, 2006 04:55 AM
