ATTN: LS/VTEC GUYS!!! what's your valve lash?
Old Mar 1, 2005 | 05:56 PM
ernald711's Avatar
Default ATTN: LS/VTEC GUYS!!! what's your valve lash?
searched... no joy!!!
just put in my ls/vtec, runs great, but i do have some minor ticking fom the vavle lash. i set it to an oem b16 setting... is this right or do you guys recommend different #'s. thanks in advance for your help!!!
Old Mar 2, 2005 | 12:08 AM
ernald711's Avatar
Default Re: ATTN: LS/VTEC GUYS!!! what's your valve lash? (ernald711)
come on... all you lsvtec guys.. help me out....
Old Mar 2, 2005 | 07:45 AM
b19coupe's Avatar
Stock lash should be fine. 0.17mm intake, 0.19mm exhaust.
Old Mar 2, 2005 | 08:59 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: ATTN: LS/VTEC GUYS!!! what's your valve lash? (b19coupe)
I'm running .009" because thats where WebCams wants the valve lash to be set at. Your LMAs could also be sticking too if your valve lash is set to stock.
Old Mar 2, 2005 | 04:45 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Stock lash should be fine. 0.17mm intake, 0.19mm exhaust.</TD></TR></TABLE>
what do you mean... are yours set to 0.17 and 0.19. i saw the stock b16's are .006-.007 and .007-.008... what's this 0.17/0.19
Old Mar 2, 2005 | 05:33 PM
b19coupe's Avatar
0.17mm and 0.19mm. It translates into 0.007" and 0.008", roughly.
Old Mar 2, 2005 | 05:59 PM
tONE.steR's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean... are yours set to 0.17 and 0.19. i saw the stock b16's are .006-.007 and .007-.008... what's this 0.17/0.19</TD></TR></TABLE>
One is in inches and the other in millimeters.
Your lash setting should be stock, if you're running stock cams.
.17mm / 25.4 = .00669"
.19mm / 25.4 = .00748"
Old Mar 2, 2005 | 07:51 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">0.17mm and 0.19mm. It translates into 0.007" and 0.008", roughly.</TD></TR></TABLE>
ah ha.... thanks bro.. thanks everyone for all your help... no more ticking soon... i hope
Old Mar 2, 2005 | 09:32 PM
ea_hatch's Avatar
7 and 8 but that has already been said
Old Mar 14, 2005 | 07:38 PM
ernald711's Avatar
Default Re: (ea_hatch)
now... what's the torque specs for these bad boys... i hate this pinging
Old Mar 14, 2005 | 07:40 PM
Banned
Default Re: (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">now... what's the torque specs for these bad boys... i hate this pinging</TD></TR></TABLE>
Torque spec for the lock nuts? When I adjust mine I just tighten them up snug.
Old Mar 14, 2005 | 08:03 PM
3.504's Avatar
Default Re: (LSVTEC 91 Civic)
torque spec = 20nm or 14lb/ft
Old Mar 14, 2005 | 08:13 PM
ernald711's Avatar
Default Re: (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">torque spec = 20nm or 14lb/ft </TD></TR></TABLE>
thanks...
Ruben19
May 25, 2009 01:05 PM
integrawow
21
Apr 26, 2009 01:10 AM
mrfi2
Sep 12, 2004 05:30 PM
ThatRicerDaniel
Dec 13, 2003 09:52 PM
