how do i check for offset on my wheel?
Sometimes it's stamped along with the rim size, like 16 x 7" ET45 where ET45 means 45mm offset. I think some stock Honda rims just say 45 without "ET".
You can measure it if you've got a couple straightedges to lay across the rim (inside & out), & measure thru the spokes from one side to the other. Check out the diagram on http://www.tirerack.com where they explain what offset is, post back if you don't understand it.
nugget666
May 17, 2006 02:58 AM
