omni coilovers spring rates?
Old Mar 1, 2005 | 04:25 PM
slowem1si's Avatar
Default omni coilovers spring rates?
i just received my set of omni slip on coilovers for my 94 ls and there are differerent spring rates on two and obviously the other two are different too. IM just wondering if anyone can tell me which two go in the front and which two go in the rear?
here are the two different numbers i have
0178.63.5.008
0178.63.5.006
thanks for the help
Old Mar 1, 2005 | 04:37 PM
Evanmb44's Avatar
Default Re: omni coilovers spring rates? (Mr._G-unit)
um.....ya, the fronts are totally different from the backs. the ones that mount over the lca's have the two holes on the bottom for the bolt to go through. the fronts dont have any holes on the bottom at all.
and the spring rates:
streets:
front: 10k
rear: 8k
sports:
front: 12k
rear: 10k
hope that helps
Old Mar 1, 2005 | 04:47 PM
slowem1si's Avatar
Default Re: omni coilovers spring rates? (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">um.....ya, the fronts are totally different from the backs. the ones that mount over the lca's have the two holes on the bottom for the bolt to go through. the fronts dont have any holes on the bottom at all.
streets:
front: 10k
rear: 8k
sports:
front: 12k
rear: 10k
hope that helps</TD></TR></TABLE>
i didn't buy full coilovers they are just slip on coilovers... all four of the springs are very simular in size so its hard to tell
Old Mar 1, 2005 | 04:53 PM
Integgin's Avatar
Your right they all look the same...but the ones that say .06 are for the rear..and the ones that say .08 are in the front...I had that question too!!...Take kare..and they are great coilovers..but dont go too low or ull bottom out on stock shocks buddy
Old Mar 1, 2005 | 04:54 PM
slowem1si's Avatar
Default Re: omni coilovers spring rates? (Integgin)
thanks alot buddy im gonna use aftermarket struts too, and omni lcas and a onmi camber kit just needed to know this b 4 the install... thanks
Old Mar 1, 2005 | 05:22 PM
hotsuma23's Avatar
nice, where did you buy yours from and how much? Im goingt be picking up a set soon to pair with some tokico illuminas. Let me know how they are.
Old Mar 1, 2005 | 06:21 PM
slowem1si's Avatar
Default Re: omni coilovers spring rates? (hotsuma23)
i bought them for $165 from http://www.kteller.com
Old Mar 1, 2005 | 06:56 PM
hotsuma23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr._G-unit &raquo;</TD></TR><TR><TD CLASS="quote">i bought them for $165 from http://www.kteller.com </TD></TR></TABLE>
Dude, Thanks a lot! That is the best price I have seen anywhere. How long did it take you to get them?
Old Mar 1, 2005 | 07:20 PM
Evanmb44's Avatar
sorry
i didnt read that they were the slip on ones
my bad dude
Old Mar 1, 2005 | 07:27 PM
Chris F's Avatar
The LAST number is the spring rate.
006 = 6K
008 = 8K
Generally speaking, put the heavy ones in front.
-Chris
(ITR Omni sports, 12k front, 10K rear)
Old Mar 1, 2005 | 07:54 PM
LilChuck's Avatar
Default Re: omni coilovers spring rates? (Chris F)
I was just wondering why always put the stiffer in the front? Anyone have a valid explanation for this? Thanks.
~Chuck
Old Mar 2, 2005 | 03:48 AM
slowem1si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotsuma23 &raquo;</TD></TR><TR><TD CLASS="quote">
Dude, Thanks a lot! That is the best price I have seen anywhere. How long did it take you to get them? </TD></TR></TABLE>
5 days k-teller is good about shipping
Old Mar 2, 2005 | 05:25 AM
Chris F's Avatar
Default Re: omni coilovers spring rates? (LilChuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilChuck &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering why always put the stiffer in the front? Anyone have a valid explanation for this? Thanks.
~Chuck</TD></TR></TABLE>
"Heavy end of the car gets the heavy springs" is the old-school/Japan way of thought. You then fix understeer with swaybars. Front and rear have springs that match the relative load of the car.
US Honda racers started putting heavy springs in the rear. Ride quality obviously suffers (front end is relatively under-spring, rear is over-sprung, considering the rear is much lighter).
There's a good write-up on this somewhere...
but I can't find it. In the meantime...
https://honda-tech.com/zerothread?id=1137183
Old Mar 2, 2005 | 07:05 AM
Cabby89's Avatar
Can someone explain the spring rating to me??
Im used to VW and only know of spring rates in lbs. Those numbers dont seem right if they were rated the same way. Cause most street cars run 100lbs from the factory and the average track car will run from 500-800lbs rates.
Old Mar 2, 2005 | 07:11 AM
Chris F's Avatar
Default Re: omni coilovers spring rates? (Cabby89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cabby89 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone explain the spring rating to me??
Im used to VW and only know of spring rates in lbs. Those numbers dont seem right if they were rated the same way. Cause most street cars run 100lbs from the factory and the average track car will run from 500-800lbs rates.</TD></TR></TABLE>
When I say "12k", I mean 12 kilograms per millimeter.
When you say "800 lbs", you mean 800 lbs per inch.
You can use "Google calculator" to do a conversion. It's awesome.
12 kg/mm in lbs/inch:
http://www.google.com/search?s...Finch
12 (kg / mm) = 671.968975 pounds / inch
Old Mar 2, 2005 | 09:31 PM
Cabby89's Avatar
Ok cool didnt know that. Why the difference in the measurement there rated in?
Old Mar 3, 2005 | 05:20 AM
Chris F's Avatar
English vs. Metric units, that's it. Depends on where the springs are made, and what kind of car they're for.
Ever wonder why tires are measured in a combination of mm, %, and inches?
205/50R15 &lt;--- 205 mm wide, sidewall height is 50% of 205, wheel is 15 inches tall.
Old Mar 3, 2005 | 07:27 PM
stealthmode62's Avatar
well now that you brought that up, why do "truck guys" call thier tires "35's) but there isn't a 35 anywhere on the tire.
I'll finally get an A+ in Life 101 if you can explain that one.
Old Mar 3, 2005 | 07:56 PM
Chris F's Avatar
Default Re: omni coilovers spring rates? (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> well now that you brought that up, why do "truck guys" call thier tires "35's) but there isn't a 35 anywhere on the tire.
I'll finally get an A+ in Life 101 if you can explain that one. </TD></TR></TABLE>
Bastards switched the convention to something that made some sense.
Let's break this one down...
35X12.50R15LT
Tire OUTSIDE diameter is 35" (******* hooray! A number that we could use!)
Tire is 12.5 inches wide (Hey, another useful number!)
Wheel diameter is 15". (OK, we got that already)
LT :: Light Truck (as opposed to Passenger tire P205/45R16)
Old Mar 3, 2005 | 09:44 PM
that's strange. Everytime I look for that 30 or 31 or 35 on the tire, I see the standard 255/89/blah blah.
This is bugging me now.
Old Mar 4, 2005 | 06:17 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">that's strange. Everytime I look for that 30 or 31 or 35 on the tire, I see the standard 255/89/blah blah.
This is bugging me now. </TD></TR></TABLE>
It is pretty obnoxious. You can find stores that sell them with both measurements. You can also go back and calculate the number.
35x12.5x15:
12.5" wide == 315mm wide
sidewall height is (35-15)/2 = 10 inches. 10/12.5 == 80 profile
This tire is a 315-80R15.
Old Mar 4, 2005 | 07:49 AM
KTeller8's Avatar
another rule of thumb would be 1k=56lbs
Old Mar 4, 2005 | 08:23 AM
Chris F's Avatar
Default Re: omni coilovers spring rates? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">another rule of thumb would be 1k=56lbs</TD></TR></TABLE>
Naw, that's too easy!
anzai
Jun 26, 2011 10:28 AM
Die-Laughing
Suspension & Brakes
10
Dec 31, 2008 08:12 AM
combustion
Oct 23, 2003 05:50 AM
civickidd99
Aug 13, 2003 07:11 PM
