Changing my spark plugs the other day and I found traces of oil/gas in the spark plug chambers
Old Mar 1, 2005 | 03:47 PM
dman81's Avatar
Default Changing my spark plugs the other day and I found traces of oil/gas in the spark plug chambers
I wanted to know what the problem may be? My dad said it may be the gaskets that have worn out and need replacing. What do you guys suggest?
THX
Old Mar 1, 2005 | 04:28 PM
bigbert's Avatar
Default Re: Changing my spark plugs the other day and I found traces of oil/gas in the spark plug chambers (
yup i had the same thing. if you go to a parts store and buy a crank case gasket set 30-40 dollars it will do the trick.
Old Mar 1, 2005 | 05:24 PM
BaddMo2002's Avatar
yup..valve cover gasket and o-rings. and might as well put in new plugs.
Old Mar 4, 2005 | 10:13 PM
dman81's Avatar
Glad to see some responses. So what do you think the problem is? Just worn out gaskets?
Old Mar 5, 2005 | 03:22 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dman81 &raquo;</TD></TR><TR><TD CLASS="quote">Glad to see some responses. So what do you think the problem is? Just worn out gaskets?
Yes....between the constant change of heat and cooling those rubber gaskets get worn out, just be thankful they are easy to replace .
Old Mar 6, 2005 | 12:34 AM
as_fast_as_u's Avatar
does your car smoke out of exhaust?
Old Mar 7, 2005 | 10:20 AM
dman81's Avatar
No, none at all.
tonyw85
May 5, 2008 02:17 PM
itslogz
Mar 26, 2008 10:24 AM
integra racr04
Jul 25, 2006 06:38 PM
200k mile sol
Mar 4, 2006 09:06 PM
Methane2k2
May 8, 2005 03:20 PM
