H22 starting problems
ok i did a search with some results but nothing for sure. so heres my problem. 94 accord with H22a completely wired right. car strated just fine, let it idle for couple minutes. turned the car off to add cooliant and it would not restart even after letting set for couple minutes. ive got fire, and fuel. any help guys?
Check your distributor. Is this a Japanese H22 with internal coil distributor? These distributors go out like there's no tomorrow. I was running fine before and all of sudden I tried starting my car one day and it didn't want to start. Also, changing ECUs. If you're using the P13, try putting in your Accord one and see if that works. But most likely, it seems to be a dead distributor.
