question about antilock brakes on my swapped civic
Old Mar 1, 2005 | 03:05 PM
ablack934doorcivic's Avatar
Default question about antilock brakes on my swapped civic
i swapped a b16 jdm motor and jdm ecu into my 93 civic 4 door ex now my anti lock brakes don't seem to be working i was wondering if anybody could help out. firt i checked and replaced all the fuses and made sure the plugs for the abs were all hooked up but still nothing. any advise?
Old Mar 1, 2005 | 03:37 PM
dantastic's Avatar
Default Re: question about antilock brakes on my swapped civic (ablack934doorcivic)
does your ABS light come on when you switch the ignition to position II? also did u get ABS b-series axles? if not, you need to transfer the ABS rings from your stock axles to your new bseries ones
Old Mar 2, 2005 | 05:05 PM
Default Re: question about antilock brakes on my swapped civic (dantastic)
no abs light that i know of , and the axles came with the swap so i don't know if they came with the ring. what does ths abs ring look like
Old Mar 2, 2005 | 05:24 PM
jbs's Avatar
jbs
Silver ring around the driveshaft toward the hub with "teeth" for the sensor.
Old Mar 2, 2005 | 05:40 PM
Default Re: question about antilock brakes on my swapped civic (jbs)
thatv would probally be why it dosen't work i don't think it has that on it
jmurphy
15
Mar 29, 2011 04:25 AM
realis9
May 30, 2008 12:55 AM
shortycm17
Dec 26, 2007 03:31 PM
jarven93
Jan 3, 2007 11:54 AM
civic702
Feb 23, 2004 04:20 PM
