Installing new gauge faces DIY?
Old Mar 1, 2005 | 02:11 PM
Chaser4dr's Avatar
Default Installing new gauge faces DIY?
Hello everyone. And before you motion to have this closed, I have already searched the boards for almost 20 minutes now trying to find a thread on this, all I can find is dash swapping. I plan on buying a set of indiglo gauge faces, but want to install them myself. Does anyone know where there is a DIY for removing the cluster and gauge faces in a '96 Civic LX? I have heard its not that hard, just have to watch the needles. Thanks for your help.
Old Mar 1, 2005 | 02:25 PM
-Gambit-'s Avatar
Default Re: Installing new gauge faces DIY? (Chaser4dr)
there are like 2 phillips screws at the top of your gauge cluster bezle thing, take those out and pull that our of place, but becareful not to break the clips at the bottom of it. Then there will be 4 phillips screws holding in the cluster take those out, and unplug the 3 wire connectors that are connected to the cluster. And your cluster is free of the car. Then you just have to unclip the clear plastic cover that is on top of your cluster. Then your in there for 05
Old Mar 1, 2005 | 02:31 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Installing new gauge faces DIY? (-Gambit-)
Search Results
Your search for swap gauge returned 29 results.
» New Search
Search archives under EG/EK+ for "gauge swap", you'll probably find some good stuff in one of those 29 threads.
Old Mar 1, 2005 | 02:54 PM
Chaser4dr's Avatar
Thanks for your help guys, appreciate it.
SC2.2CL
Mar 29, 2006 11:03 AM
CrazyHondaBoy
Jul 6, 2002 10:53 PM
