Maintenance parts for 1st Gen B16A
Old Mar 1, 2005 | 01:47 PM
JSpecEF9's Avatar
Default Maintenance parts for 1st Gen B16A
I've got a 1st Gen B16 in my Civic... Experiencing some hesitation at constant cruising rpm...
I'm going to do plugs, plug wires, distributor cap and rotor this evening... But i've only managed to find the plug information:
BKR6E-N11 NGK Standard
As far as the rest... Do I spec for a DelSol VTec?
Thanks in advance
Old Mar 1, 2005 | 01:58 PM
krazie1's Avatar
BANNED
Default Re: Maintenance parts for 1st Gen B16A (JSpecEF9)
for my tune up or rebuild of my old b16a set up
I used 90-93 integra parts with some Vtec parts needed from the 92-93 Gsr
it is cheaper as the older the car less out of ur pocket
check it and u will see
crxnj's Avatar
you can use a 88-91 civic/crx dizzy cap and rotor..
Source parts from the 99-00 civic si,del sol dohc vtec,90-93 integra..There was a writeup on here a while back that had a parts list for the j-spec b16a
Old Mar 1, 2005 | 01:59 PM
CLICC916's Avatar
yep, just get stuff for 94-95 del sol vtec or 99-00 civic si...92-93 gsr also works for most basic maintenence related stuff (caps/plugs/wires)...but the b16 stuff would be better
Old Mar 1, 2005 | 02:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/zerothread?id=1024595
Old Mar 1, 2005 | 02:14 PM
doublethink's Avatar
b16a plug gap get .044 which is the same as 90-93 integras
and yea the rest is in that thread. big ups to "crxdx"
Old Mar 1, 2005 | 02:16 PM
crxtreme89h's Avatar
Default Re: Maintenance parts for 1st Gen B16A (doublethink)
Sounds like TPS. Try swapping a buddies TPS, or look for one at a junk yard.
Old Mar 1, 2005 | 03:17 PM
red_crx's Avatar
to solve your hesitation problems, try switching the O2 sensors around.
Old Mar 1, 2005 | 03:42 PM
thatbluecrx's Avatar
Default Re: (red_crx)
If the motor before the b16 wasnt multi point, you may have to rewire the TPS, by swapping the voltage wires...
Old Mar 1, 2005 | 03:47 PM
FalkenSiR's Avatar
Default Re: (thatbluecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">If the motor before the b16 wasnt multi point, you may have to rewire the TPS, by swapping the voltage wires...</TD></TR></TABLE>
If this was the problem, then the ecu would think that the throttle is wide open all the time, not cause hessitation. Obviously, imo it looks like a maintanance problem
Old Mar 1, 2005 | 04:32 PM
mar778c's Avatar
Community Builder
Community Influencer
Exactly, do like the man says, switch the o2 sensor wires an the hesitation will disappear.
Old Mar 1, 2005 | 04:50 PM
88DXCRX's Avatar
Default Re: (mar778c)
The sensors should be wired as shown..
Swapping the positions of the two O2 sensors in the exhaust manifold
will allow the round one to be plugged into the stock location..
If you just plugged it in and then added
another wire it is probably backwards..
Old Mar 1, 2005 | 05:02 PM
Los.'s Avatar
what 02 sensors are compatible for the first gen b16?
Old Mar 1, 2005 | 05:41 PM
EFOSV's Avatar
i think i got that hesitation problem ....
Old Mar 1, 2005 | 05:44 PM
fourthgenhatchB17's Avatar
Default Re: (crxkid88Sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkid88Sir &raquo;</TD></TR><TR><TD CLASS="quote">what 02 sensors are compatible for the first gen b16? </TD></TR></TABLE>
Same ones on the D16A6. I got NTK's (NGK brand) new at a local parts house for like 16$ or so each.
Old Mar 1, 2005 | 07:12 PM
mar778c's Avatar
Community Builder
90-91 integra
Old Mar 1, 2005 | 08:25 PM
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
If this was the problem, then the ecu would think that the throttle is wide open all the time, not cause hessitation. Obviously, imo it looks like a maintanance problem </TD></TR></TABLE>
thats weird cause i had a hesitation, rewired the tps, and its gone...
z6hatchboy
Aug 6, 2008 03:59 PM
bara6075
Mar 31, 2008 06:31 PM
Jayponce
Sep 7, 2007 01:46 PM
spooned out
Aug 21, 2003 07:25 AM
WindyIce
Dec 12, 2002 09:34 AM
