short shifter-synchros?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL!M »</TD></TR><TR><TD CLASS="quote">It doesnt change anything, just the length of your throw.</TD></TR></TABLE>
the change in throw makes the difference. you have to shift slower to match the stock shifter movement or you are still forcing the synchros to work faster.
if you are careful then no harm will be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Shifters don't hurt synchros, the drivers shifting style does.</TD></TR></TABLE>
Correct. You shouldn't be buying a short shifter if you want to shift faster because shifting faster than your stock shifter is already capable of will result in increased syncro wear. The faster you shift, the less time your synchros have to work effectively. So if you shift the exact same way you would with your normal stock shifter I don't see how a short shifter could cause any excessive wear on your synchros. Only when you abuse the ability to shift faster with the shorter shift throws do you put additional strain on your synchros.
honda_coupe
24
Apr 26, 2007 08:46 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
grinding is usually a good indicator
