REPLACING HOSES PLEASE HELP
Old Mar 1, 2005 | 01:11 PM
ELAMINT5's Avatar
Default REPLACING HOSES PLEASE HELP
I am in terrible need of some help. I just got my build back and I want to replace every hose under the hood except for the radiator hoses. The motor is out still.
I took my Helms book with me to the dealership and they said that it did not help them defined which hoses I needed. So I told them that I wanted every hose under the hood and they replied which hoses. I wanted to say every hose dumbass, but I restrained.
Does any one know the name of all of the hoses so I can order these. i would love to drive my car this month it has been 6 since I last drove it. Another way I tried explaining it to the dealership was I needed every hose/line that goes from one place on the motor to another.
PLEASE HELP ME!
Old Mar 1, 2005 | 02:40 PM
eda6's Avatar
Default Re: REPLACING HOSES PLEASE HELP (ELAMINT5)
Don't waste your $ at the stealership. Get hoses from autozone.
Old Mar 1, 2005 | 02:46 PM
ELAMINT5's Avatar
Default Re: REPLACING HOSES PLEASE HELP (eda6)
are they the same quality? I figured that OEM ones would be better no?
Old Mar 1, 2005 | 03:09 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 &raquo;</TD></TR><TR><TD CLASS="quote">are they the same quality?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 &raquo;</TD></TR><TR><TD CLASS="quote">I figured that OEM ones would be better no?</TD></TR></TABLE>
I only use dealer hoses if the hose that needs to be replaced has a 180 deg bend. By the time you make the autozone hose bend 180 degrees w/o kinking it will be twice as long as it needs to be.
My hatch has all new hoses. The only hoses i got at the dealer were the two that go from the intake manifold to the t-stat housing.
Old Mar 1, 2005 | 03:59 PM
ELAMINT5's Avatar
they are all the same size hose right?
Old Mar 1, 2005 | 04:24 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 &raquo;</TD></TR><TR><TD CLASS="quote">they are all the same size hose right? </TD></TR></TABLE>
nope. Two sizes 5/16" and 5/8" inner diameter. Might want to change the vacuum hoses since you're replacing hoses. 3/16" for those.
brake booster vacuum hose is a dealer item.
Old Mar 2, 2005 | 06:06 AM
ELAMINT5's Avatar
I would not need anywhere near 3 foot of the the 5/16, 3 ft of the 5/8, and 2 ft of 3/16 to do the entire bay woudl I?
Old Mar 2, 2005 | 06:10 AM
Honda Hick's Avatar
Just go to:
http://www.hondaautomotivepart...y.jsp
and order every hose there is. They are a crapload cheaper than the dealer and you can see what yer buying.
Lexxi_TegK24
Aug 1, 2014 11:37 AM
judd_123
Sep 29, 2010 08:59 AM
SmasonGSR
Jun 25, 2004 08:56 PM
96Integ
Jun 29, 2003 04:07 AM
JASON77
Apr 25, 2003 03:23 PM
